I am trying to use 4 SparkFun Micropressure sensors with an Adafruit TCA9548A but am having problems with both errors and not knowing how to hook them up correctly. (I'm using the library for Adafruit's equivalent MPRLS sensor.)
Here is my code:
void TCA9548A(uint8_t bus) { //Setup for Adafruit Multiplexer
Wire.beginTransmission(0x70);
Wire.write(1<< bus);
Wire.endTransmission;
Wire.begin();
TCA9548(1);
boolean Adafruit_MPRLS1::begin;
Here is the error I'm getting:
Arduino: 1.8.15 (Windows 10), TD: 1.54, Board: "Teensy 4.1, Serial, 600 MHz, Faster, US English"
Final_I2C: In function 'void TCA9548A(uint8_t)':
Final_I2C:14: error: statement cannot resolve address of overloaded function
Final_I2C: In function 'void setup()':
Final_I2C:23: error: 'TCA9548' was not declared in this scope
TCA9548(1);
Final_I2C:24: error: 'Adafruit_MPRLS1' has not been declared
Final_I2C:24: error: qualified-id in declaration before ';' token
option enabled in File -> Preferences.
Sorry for not sending all the code, here is the entire thing:
#define SysValve 1
#define DistValve 2
#define MidValve 3
#define ProxValve 4
#define Address 0x70 //Setup to connect to the Sparkfun MicroPressure sensors
#include <Wire.h>
#include <Adafruit_MPRLS.h>
Adafruit_MPRLS mpr = Adafruit_MPRLS(-1, -1);
Wire.write(1 << bus);
Wire.endTransmission();
Wire.begin();
TCA9548(1);
boolean Adafruit_MPRLS1::begin();
pinMode(SysValve, OUTPUT); //Setting the output pins to the valves:
pinMode(DistValve, OUTPUT);
pinMode(MidValve, OUTPUT);
pinMode(ProxValve, OUTPUT);
pinMode(A0, INPUT); //Setting which pin to read from
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A3, INPUT);
float SysPSI = analogRead(A1); //Input from sensors:
float DistPSI = analogRead(A1);
float MidPSI = analogRead(A1);
float ProxPSI = analogRead(A1);
Serial.print("System Pressure: "); //Show pressure of each chamber:
Serial.println(SysPSI);
Serial.print("Distal Chamber Pressure: ");
Serial.println(DistPSI);
Serial.print("Middle Chamber Pressure: ");
Serial.println(MidPSI);
Serial.print("Proximal Chamber Pressure: ");
Serial.println(ProxPSI);
if (SysPSI == 14.7) { //Open secondary valves if system is at atmospheric pressure:
while (DistPSI == 14.7 && MidPSI == 14.7 && ProxPSI == 14.7) {
digitalWrite(DistValve, HIGH);
digitalWrite(MidValve, HIGH);
digitalWrite(ProxValve, HIGH);
if (SysPSI < 44.7 && SysPSI > 14.7) {
if ( (DistPSI == 14.7 && MidPSI == 14.7 && ProxPSI == 14.7) || (DistPSI < SysPSI && MidPSI < SysPSI && ProxPSI < SysPSI)) {
while (DistPSI != SysPSI && MidPSI != SysPSI && ProxPSI != SysPSI) {
digitalWrite(SysValve, HIGH); //If system pressure is between the max PSI and atmospheric pressure while the secondary pressure is < system pressure open the 1st valve:
if (DistPSI > SysPSI) { // :
while (DistPSI != SysPSI) {
while (MidPSI != SysPSI) {
while (ProxPSI != SysPSI) {
digitalWrite(SysValve, LOW);
digitalWrite(DistValve, LOW);
digitalWrite(MidValve, LOW);
digitalWrite(ProxValve, LOW);
I'm still getting some errors from the code:
TCA9548(1);
Final_I2C:24: error: qualified-id in declaration before '(' token
Thank you your help, sorry again for not sending the entire thing, this is the first time I've asked for help with code/errors.
You can not compare it with 14.7, because it might be a little more or a little less.
You could do this:
if( SysPSI > 12.0 && SysPSI < 17.4)
The analogRead() function does not return a floating point number with the psi. You have to calculate the psi if that sensor has a analog output. But the Sparfun MicroPressure Sensors do not have a analog output.
See the example how to get the pressure with: "mpr.readPressure();"
#define SysValve 1
#define DistValve 2
#define MidValve 3
#define ProxValve 4
#include <Wire.h>
Wire.begin();
mpr.begin();
TCA9548A(1);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A3, INPUT);
float SysPSI = mpr.readPressure(); //Input from sensors:
float DistPSI = mpr.readPressure();
float MidPSI = mpr.readPressure();
float ProxPSI = mpr.readPressure();
if ((SysPSI < 48 && SysPSI > 40) && (SysPSI > 12.0 && SysPSI < 17.4)) {
I'm still getting a few errors though:
Final_I2C:25: error: 'Adafruit_MPRLS1' has not been declared
Final_I2C:25: error: qualified-id in declaration before '(' token
Have you seen the example ?
Did you see this in the example :
I don't. I also don't know where it is coming from or why that is in the sketch.
The compiler can tell what a problem is, but you have to understand what the compiler is trying to tell. That line gives two compiler error that something is not declared. The compiler is saying: "Huh, what is this".
This code will read the same sensor 4 times and get 4 readings which are the same or almost the same. It will assign those 4 similar readings to 4 variables which were meant to hold readings from 4 different sensors.
