Hello everyone I hope you are doing well.
I am coding my own smart car park utilising the following components:
- Arduino Mega
- 4 x Ultrasonic sensors
- 1 x OLED
- 1x servo motor
The idea behind this is that 1 ultrasonic sensor is used to open the gate to the car park (servo motor) whilst the other three sensors are used to display the parking slots in the park.
My problem is that I wish to use the ultrasonic sensors to display a space being taken up in the car park and this information being displayed on an OLED.
I cannot seem to count the number of slots available, and if one frees up, also display this on the OLED.
I would like to display the number of car slots available, and when one is used up, this is displayed on the OLED showing "2 slots available"; if another one is used up, deduct this value from the other car slot taken up and displaying "1 slot available".
Here is the current copy of my code below:
// This project uses an Arduino MEGA to house more ultrasonic sensors
// Define ultrasonic sensor parameters
int trigPin = 5;
int echoPin = 6;
long duration;
int distance;
int trigPin2 = 8;
int echoPin2 = 9;
long duration2;
int distance2;
int trigPin3 = 19;
int echoPin3 = 18;
long duration3;
int distance3;
int DelayTime = 1000;
int OLEDTime = 500;
int C1 = 3;
int C2 = 2;
int C3 = 1;
int C4 = 0;
int currentVal;
int x = 1;
int y = -1;
String currentState = "CLOSED";
// Define OLED parameters //
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
Adafruit_SSD1306 oled(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
// Define Servo Motor //
#include <Servo.h>
Servo myservo;
int pos = 0;
// Define Ultrasonic function //
long Ultrasonic() {
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = duration * 0.034/2;
long Ultrasonic2() {
digitalWrite(trigPin2, LOW);
digitalWrite(trigPin2, HIGH);
duration2 = pulseIn(echoPin2, HIGH);
distance2 = duration2 * 0.034/2;
long Ultrasonic3() {
digitalWrite(trigPin3, LOW);
digitalWrite(trigPin3, HIGH);
duration3 = pulseIn(echoPin3, HIGH);
distance3 = duration3 * 0.034/2;
void clearOLED() {
oled.clearDisplay();
oled.setTextSize(8);
oled.setTextColor(WHITE);
oled.setCursor(1,20);
oled.println("");
oled.display();
String open_gate_OLED() {
oled.setTextSize(1);
oled.setCursor(40,30);
oled.println("GATE OPEN");
oled.display();
return "OPEN";
String close_gate_OLED() {
oled.setCursor(30,30);
oled.println("GATE CLOSED");
oled.display();
return "CLOSED";
int slots_used() {
oled.setCursor(19,30);
oled.print("SLOTS AVAILABLE: ");
oled.setCursor(62,40);
oled.println(C1-1);
oled.display();
delay(OLEDTime);
return currentVal;
int slots_available() {
oled.println();
oled.display();
delay(OLEDTime);
return currentVal;
if (!oled.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
while (true);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(trigPin2, OUTPUT);
pinMode(echoPin2, INPUT);
pinMode(trigPin3, OUTPUT);
pinMode(echoPin3, INPUT);
myservo.attach(3);
Ultrasonic();
Ultrasonic2();
Ultrasonic3();
Serial.print(distance3);
Serial.println(" cm");
if (currentState == "CLOSED" && distance <= 10) { // This part of code will open the gate to 180 if the distance is less that 10cm for one of the ultrasonic sensors
delay(DelayTime); // This will be displayed on the OLED saying GATE OPEN
distance = Ultrasonic();
if (distance <= 10) {
myservo.write(180);
delay(OLEDTime);
currentState = open_gate_OLED();
else if (distance >= 10) { // And if the distance is more than 10 cm for the DelayTime of 1s, then the gate will shut
delay(DelayTime); // It will be displayed on the OLED saying GATE CLOSED
myservo.write(pos);
delay(OLEDTime);
currentState = close_gate_OLED();
if (distance2 <= 3) {
delay(DelayTime);
distance2 = Ultrasonic2();
slots_used();
if (distance3 <= 3) {
delay(DelayTime);
distance3 = Ultrasonic3();
slots_used();
else if (currentVal == C2) {
oled.println(C1-1);
oled.display();
delay(OLEDTime);
