Hello,
I am trying to cycle through and print values of a multiplexer to the serial monitor. However, I need to go through all the values at a certain frequency, so I need to use timer1 and an interrupt verify the sampling frequency.
I am using a Pro Mini 328 8MHz. I have tested the timer-interrupt code with LEDs and other components, so I know I have that part working. However, when I put in the multiplexer code, the arduino outputs nothing. The multiplexer code is sound as well; when put into the loop(), it works perfectly. But whenever I mix it with the timer and interrupt code, things go all wrong.
By the way, we are using this multiplexer, if it changes anything: SparkFun Analog/Digital MUX Breakout - CD74HC4067 - BOB-09056 - SparkFun Electronics
Here is the code that outputs nothing:
int x, y, z;
//Mux control pins
int s0 = 13;
int s1 = 12;
int s2 = 11;
int s3 = 10;
int SIG_pin = 0;
int controlPin[] = {s0, s1, s2, s3};
int muxChannel[16][4]={
{0,0,0,0}, //channel 0
{1,0,0,0}, //channel 1
{0,1,0,0}, //channel 2
{1,1,0,0}, //channel 3
{0,0,1,0}, //channel 4
{1,0,1,0}, //channel 5
{0,1,1,0}, //channel 6
{1,1,1,0}, //channel 7
{0,0,0,1}, //channel 8
{1,0,0,1}, //channel 9
{0,1,0,1}, //channel 10
{1,1,0,1}, //channel 11
{0,0,1,1}, //channel 12
{1,0,1,1}, //channel 13
{0,1,1,1}, //channel 14
{1,1,1,1} //channel 15
pinMode(s0, OUTPUT);
pinMode(s1, OUTPUT);
pinMode(s2, OUTPUT);
pinMode(s3, OUTPUT);
digitalWrite(s0, LOW);
digitalWrite(s1, LOW);
digitalWrite(s2, LOW);
digitalWrite(s3, LOW);
cli(); //stop interrupts
//set timer1 interrupt at 10Hz
TCCR1A = 0; // set entire TCCR1A register to 0
TCCR1B = 0; // same for TCCR1B
TCNT1 = 0; //initialize counter value to 0
// set compare match register for 10hz increments
OCR1A = 780;//
// turn on CTC mode
TCCR1B |= (1 << WGM12);
// Set CS12 and CS10 bits for 1024 prescaler
TCCR1B |= (1 << CS12) | (1 << CS10);
// enable timer compare interrupt
TIMSK1 |= (1 << OCIE1A);
sei();//allow interrupts
ISR(TIMER1_COMPA_vect)
// Loop through and read all 16 values
// Reports back Value at channel 6 is: [value]
for(int i = 0; i < 16; i++){
for(int j = 0; j < 4; j ++){
digitalWrite(controlPin[j], muxChannel[i][j]);
Serial.print("Value at channel ");
Serial.print(i);
Serial.print("is : ");
Serial.println(analogRead(SIG_pin));
Does anyone know what is going on?
