Hello everyone. Here I have my code using the eloquent. I am still confuse why I keep getting error in the line of "using namespace Eloquent::DataStructures;". Other info is that I am using the Arduino IDE of 1.8.15 version. Currently, I am doing my capstone project so fast reply would be appreciated
#include "eDataStructures.h"
#define MAX_NETWORKS 4
double features[MAX_NETWORKS];
Array knownNetworks("");
WiFi.mode(WIFI_STA);
WiFi.disconnect();
knownNetworks.push("SSID #0");
knownNetworks.push("SSID #1");
knownNetworks.push("SSID #2");
knownNetworks.push("SSID #3");
Here is the error message
Arduino: 1.8.15 (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, Flash, Enabled, Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
sketch_sep14a:5:17: error: 'Eloquent' has not been declared
5 | using namespace Eloquent::DataStructures;
sketch_sep14a:5:27: error: 'DataStructures' is not a namespace-name
sketch_sep14a:8:1: error: 'Array' does not name a type
8 | Array knownNetworks("");
D:\Arduino Data\sketch_sep14a\sketch_sep14a.ino: In function 'void setup()':
sketch_sep14a:12:5: error: 'WiFi' was not declared in this scope
12 | WiFi.mode(WIFI_STA);
sketch_sep14a:12:15: error: 'WIFI_STA' was not declared in this scope
sketch_sep14a:15:5: error: 'knownNetworks' was not declared in this scope
15 | knownNetworks.push("SSID #0");
exit status 1
option enabled in File -> Preferences.
