Hello everyone,
I am trying to build a controller for my little 1:220 model train using an arduino nano, a 12v power supply for the motor and a L298N motor controller with the speed control being a rotary encoder.
I am having trouble figuring out how to include suitable code into the sketch to control ENA on the controller with a PWm signal.
Don’t make the beginner’s mistake of trying to do too much at once or looking for a compleat solution, work on it in stages.
For a start look for a good library to handle a rotary encoder, one that uses interrupts not polling. Then just print the results of turning the knob. You will see the count increase and decrease but it will also go outside the range of 0 to 255 that you want. So then work on a way that constrains the number to the range you require.
Then you just send the number to the PWM pin. To be sure you do not refresh this too often only set the PWM pin when the number from the count has changed. This is because sending a value to the PWM resets the value and if you bombard it with requests to change you will never see a pulse out of it because it is always resetting.
Thanks for the guidance. I will check out what libraries there are and go from there. In the meantime, I will probably go with paulpaulson's suggestion to use a good old fashioned pot.
