Using NeoPixel 8 RGB for showing potentiometer value
Hi. I am making hardware volume mixer and I want the volume to be shown by LED NeoPixel. So the value of potentiometer will change how many leds are light up.
This guy made it. But I want to make transition to neopixel. So changing the library etc.
 * This is a simple example program on how to use slide pot modules with an Arduino.
 * In particular, tis programs shows how to control an WS2812B LED strip with a slide pot input.
#include "FastLED.h"
#define PIN_SLIDE_POT_A A0 // input pin of the slide pot
#define MAX_SLIDE_POT_ANALGOG_READ_VALUE 700 // maximum voltage as analog-to-digital converted value, depends on the voltage level of the VCC pin. Examples: 5V = 1023; 3.3V ~700
#define NUM_LEDS 10 // add number of LEDs of your RGB LED strip
#define PIN_LED 3 // digital output PIN that is connected to DIN of the RGB LED strip
#define LED_COLOR CRGB::DarkOrchid // see https://github.com/FastLED/FastLED/wiki/Pixel-reference for a full list, e.g. CRGB::AliceBlue, CRGB::Amethyst, CRGB::AntiqueWhite...
CRGB rgb_led[NUM_LEDS]; // color array of the LED RGB strip
  pinMode(PIN_SLIDE_POT_A, INPUT);
  FastLED.addLeds<WS2812B, PIN_LED>(rgb_led, NUM_LEDS);
  Serial.println("Setup done.");
  // 1) Analog value of slide pot is read
  int value_slide_pot_a = analogRead(PIN_SLIDE_POT_A);
  Serial.print("Slide Pot value: ");
  Serial.println(value_slide_pot_a);
  // 2) Analog value is mapped from slide pot range (analog input value) to led range (number of LEDs)
  int num_leds_switchedon = map(value_slide_pot_a, 0, MAX_SLIDE_POT_ANALGOG_READ_VALUE, 0, NUM_LEDS);
  // 3) Light up the LEDs
  // Only LEDs are switched on which correspond to the area left of the slide knob
  for (int i = 0; i < num_leds_switchedon; ++i) {
    rgb_led[i] = LED_COLOR;
  // LEDs are switched off which correspond to the area right of the slide knob
  for (int i = num_leds_switchedon; i < NUM_LEDS; ++i) {
    rgb_led[i] = CRGB::Black;
  FastLED.show();
FastLED works fine with NeoPixel.
Wait. Does it. So this code will do ?
you need to just choose the right settings in this line for the strip you have
and WS2812B are Neopixels...
Thanks.
