using normal GSM modem as GSM shield (using pin 2 ,3)
i have tried Make Voice Call example without giving pin number and worked well.
but when i tried gsm web client, it is showing error.
i am not getting any positive response for
(gsmAccess.begin(PINNUMBER)==GSM_READY) &
      (gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD)==GPRS_READY)
It would help to see the rest of the sketch, a pointer to the hardware, and any third-party libraries you are using.
I have the same problem.
I tried printing the result of this line gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD)==GPRS_READY but nothing appears in the serial output
I'm using a breakout board for SIMCOM SIM900 chip. With Arduino Leonardo.
What library are you using to deal with GPRS.I also have a SIM900 and I'm looking for a library to use gprs to do a http get
  Web client
 This sketch connects to a website through a GSM shield. Specifically,
 this example downloads the URL "http://arduino.cc/asciilogo.txt" and
 prints it to the Serial monitor.
 Circuit:
 * GSM shield attached to an Arduino
 * SIM card with a data plan
 created 8 Mar 2012
 by Tom Igoe
 http://arduino.cc/en/Tutorial/GSMExamplesWebClient
// libraries
#include <GSM.h>
// PIN Number
#define PINNUMBER "1234"
// APN data
#define GPRS_APN       "airtelgprs.com" // replace your GPRS APN
#define GPRS_LOGIN     " "    // replace with your GPRS login
#define GPRS_PASSWORD  " " // replace with your GPRS password
// initialize the library instance
GSMClient client;
GPRS gprs;
GSM gsmAccess;
// URL, path & port (for example: arduino.cc)
char server[] = "arduino.cc";
char path[] = "/asciilogo.txt";
int port = 80; // port 80 is the default for HTTP
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("Starting Arduino web client.");
  // After starting the modem with GSM.begin()
  // attach the shield to the GPRS network with the APN, login and password
  Serial.println(gsmAccess.begin(PINNUMBER));
  Serial.println(GSM_READY);
  Serial.println(gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD));
  Serial.println(GPRS_READY);
  Serial.println("connecting...");
  // if you get a connection, report back via serial:
  if (client.connect(server, port))
    Serial.println("connected");
    // Make a HTTP request:
    client.print("GET ");
    client.print(path);
    client.println(" HTTP/1.1");
    client.print("Host: ");
    client.println(server);
    client.println("Connection: close");
    client.println();
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
  // if there are incoming bytes available
  // from the server, read them and print them:
  if (client.available())
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.available() && !client.connected())
    Serial.println("disconnecting.");
    client.stop();
    // do nothing forevermore:
    for(;;)
output
0
3
2
4
connecting...
connection failed
ERROR
disconnecting.
johnwasser:
  Web client
 Circuit:
 created 8 Mar 2012
 by Tom Igoe
// libraries
#include <GSM.h>
// PIN Number
// APN data
GSMClient client;
GPRS gprs;
GSM gsmAccess;
  while (!Serial) {
    client.print(path);
    client.println();
    Serial.print(c);
    client.stop();
    for(;;)
output
0
3
2
4
connecting...
connection failed
ERROR
disconnecting.
I got this sketch from one discussion http://www.geeetech.com/wiki/index.php/Arduino_GPRS_Shield
I use a SIM900 breakout board, connected to arduino via TX1,RX0 and GND wire.
I uploaded this sketch and i'm able to get google page.
///////////// This code is for leonardo
// for boards with one serial port use software serial and replace Serial1 with mySerial
//#include <SoftwareSerial.h>
//SoftwareSerial mySerial(3, 8);
 Serial.begin(9600);    // the GPRS baud rate
 while (!Serial) { ; }
 Serial1.begin(9600);               // the GPRS baud rate
 //after start up the program, you can using terminal to connect the serial of gprs shield,
 //if you input 't' in the terminal, the program will execute SendTextMessage(), it will show how to send a sms message,
 Serial1.println("AT+CSQ");
 delay(100);
 ShowSerialData();// this code is to show the data from gprs shield, in order to easily see the process of how the gprs shield submit a http request, and the following is for this purpose too.
 Serial1.println("AT+CGATT?");
 delay(100);
 ShowSerialData();
 Serial1.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"");//setting the SAPBR, the connection type is using gprs
 ShowSerialData();
 Serial1.println("AT+SAPBR=3,1,\"APN\",\"CMNET\"");//setting the APN, the second need you fill in your local apn server
 delay(4000);
 ShowSerialData();
 Serial1.println("AT+SAPBR=1,1");//setting the SAPBR, for detail you can refer to the AT command mamual
 delay(2000);
 ShowSerialData();
 Serial1.println("AT+HTTPINIT"); //init the HTTP request
 delay(2000);
 ShowSerialData();
 Serial1.println("AT+HTTPPARA=\"URL\",\"www.google.com\"");// setting the httppara, the second parameter is the website you want to access
 ShowSerialData();
 Serial1.println("AT+HTTPACTION=0");//submit the request
 delay(10000);//the delay is very important, the delay time is base on the return from the website, if the return datas are very large, the time required longer.
 //while(!Serial1.available());
 ShowSerialData();
 Serial1.println("AT+HTTPREAD");// read the data from the website you access
 delay(300);
 while(1) { ShowSerialData(); }
 //Serial1.println("");
 //delay(100);
void ShowSerialData()
 while(Serial1.available()!=0)
   Serial.write(Serial1.read());
