Using Nrf24l01 to send sensor data in integer
I want to sent integer value of a sensor with a Nrf24l01. I can ON/OFF led or relay but dont know how to send sensor value wirelessly with Nrf24l01.
my tx code
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include<dht.h>
dht DHT;
#define DHT11_PIN 3 // if you require to change the pin number, Edit the pin with your arduino pin.
int DataMsg[1];
RF24 radio(9,10);
const uint64_t pipe = 0xE14BC8F482LL;
int Button1 = 7;
int Button2 = 2;
pinMode(7, INPUT);
digitalWrite(7,HIGH);
pinMode(2, INPUT);
digitalWrite(2,HIGH);
Serial.println("NRF24L01 Transmitter");
Serial.println("welcome to TechPonder Humidity and temperature Detector");
radio.begin();
radio.openWritingPipe(pipe);
int chk = DHT.read11(DHT11_PIN);
Serial.println(" Humidity " );
Serial.println(DHT.humidity, 1);
Serial.println(" Temparature ");
Serial.println(DHT.temperature, 1);
radio.read(&DHT.temperature, sizeof(DHT.temperature));
delay(2000);
if (digitalRead(Button1) == LOW)
Serial.println("Button 1 pressed");
DataMsg[0] = 1;
radio.write(DataMsg, 1);
if (digitalRead(Button2) == LOW)
Serial.println("Button 2 pressed");
DataMsg[0] = 2;
while(Serial.available())
char In=Serial.read();
if (In=='2' == HIGH)//relay on
Serial.println("Relay ON");
DataMsg[0] = 1;
DataMsg[0] = 1;
if (In=='1' == HIGH)//relay on
Serial.println("Relay OFF");//relay off
DataMsg[0] = 2;
DataMsg[0] = 2;
if (In=='4' == HIGH)//relay on
Serial.println("LED ON");
DataMsg[0] = 3;
radio.write(DataMsg, 3);
DataMsg[0] = 3;
if (In=='3' == HIGH)// on
Serial.println("LED OFF");//relay off
DataMsg[0] = 4;
DataMsg[0] = 4;
if (In=='6' == HIGH)//relay on
DataMsg[0] = 5;
radio.write(DataMsg, 5);
DataMsg[0] = 5;
if (In=='5' == HIGH)// on
DataMsg[0] = 6;
DataMsg[0] = 6;
My rx code
#include <SPI.h>
#include "RF24.h"
int DataMgs[3];
RF24 radio(9,10);
int Relay1 = 2;
int LED1 = 4;
int LED2 = 3;
pinMode(Relay1, OUTPUT);
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
radio.begin();
radio.openReadingPipe(1,pipe);
radio.startListening();
if (radio.available())
bool done = false;
while (!done)
done = radio.read(DataMgs, 1);
Serial.print("NRF24L01 Receiver: ");
Serial.println(DataMgs[0]);
if (DataMgs[0] == 1)
delay(10);
digitalWrite(Relay1, HIGH);
if (DataMgs[0] == 2)
delay(10);
digitalWrite(Relay1, LOW);
if (DataMgs[0] == 3)
delay(10);
digitalWrite(LED1, HIGH);
if (DataMgs[0] == 4)
delay(10);
digitalWrite(LED1, LOW);
if (DataMgs[0] == 5)
delay(10);
digitalWrite(LED2, HIGH);
if (DataMgs[0] == 6)
delay(10);
digitalWrite(LED2, LOW);
delay(100);
Serial.println("Waiting for signal...");
