Hi everyone, I'm sorry for my bad English, I will try to explain myself as good as possible.
I have an Arduino Leonardo Board. http://arduino.cc/en/Main/ArduinoBoardLeonardo
I soldered on it the Arduino Ethernet shield with the W5100 chip. http://arduino.cc/en/Main/ArduinoEthernetShield
I bought on ebay (from china) the nRF24L01+ and I'm trying to get it working.
I saw the following topics in english language about my problem but I couldn't find any solution in them:
http://arduino.cc/forum/index.php/topic,20688.0.html
http://arduino.cc/forum/index.php/topic,88015.0.html
I'm following the maniacBug tutorial at the following link: Getting Started with nRF24L01+ on Arduino | maniacbug
I've to say it is a really well done tutorial.
maniacBug personally suggested me to try to ask to the arduino forum and this is what I'm doing here ![]()
I tried also with the MIRF library but it's even worse.
I changed the RF24 configurable pins to 8 and 9 insted of 9 and 10.
I thought that the possible solution was to disable the w5100 chip putting the DP10 to high. I didn't know if I had to disable also the SD card putting the DP4 to high, I tried both but nothing worked.
Here is my code:
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
// Hardware configuration
// Set up nRF24L01 radio on SPI bus plus pins 9 & 10
RF24 radio(8,9);
// Topology
// Radio pipe addresses for the 2 nodes to communicate.
const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
// Role management
// Set up role. This sketch uses the same software for all the nodes
// in this system. Doing so greatly simplifies testing.
// The various roles supported by this sketch
typedef enum { role_ping_out = 1, role_pong_back } role_e;
// The debug-friendly names of those roles
const char* role_friendly_name[] = { "invalid", "Ping out", "Pong back"};
// The role of the current running sketch
role_e role = role_pong_back;
void setup(void)
pinMode(10, OUTPUT);
pinMode(4, OUTPUT);
//disable the W5100 chip
digitalWrite(10, HIGH);
//disable sd card
digitalWrite(4, HIGH);
// Print preamble
Serial.begin(57600);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
printf_begin();
printf("\n\rRF24/examples/GettingStarted/\n\r");
printf("ROLE: %s\n\r",role_friendly_name[role]);
printf("*** PRESS 'T' to begin transmitting to the other node\n\r");
// Setup and configure rf radio
radio.begin();
// optionally, increase the delay between retries & # of retries
radio.setRetries(15,15);
// optionally, reduce the payload size. seems to
// improve reliability
//radio.setPayloadSize(8);
// Open pipes to other nodes for communication
// This simple sketch opens two pipes for these two nodes to communicate
// back and forth.
// Open 'our' pipe for writing
// Open the 'other' pipe for reading, in position #1 (we can have up to 5 pipes open for reading)
//if ( role == role_ping_out )
//radio.openWritingPipe(pipes[0]);
radio.openReadingPipe(1,pipes[1]);
//else
//radio.openWritingPipe(pipes[1]);
//radio.openReadingPipe(1,pipes[0]);
// Start listening
radio.startListening();
// Dump the configuration of the rf unit for debugging
radio.printDetails();
void loop(void)
// Ping out role. Repeatedly send the current time
if (role == role_ping_out)
// First, stop listening so we can talk.
radio.stopListening();
// Take the time, and send it. This will block until complete
unsigned long time = millis();
printf("Now sending %lu...",time);
bool ok = radio.write( &time, sizeof(unsigned long) );
if (ok)
printf("ok...");
printf("failed.\n\r");
// Now, continue listening
// Wait here until we get a response, or timeout (250ms)
unsigned long started_waiting_at = millis();
bool timeout = false;
while ( ! radio.available() && ! timeout )
if (millis() - started_waiting_at > 200 )
timeout = true;
// Describe the results
if ( timeout )
printf("Failed, response timed out.\n\r");
// Grab the response, compare, and send to debugging spew
unsigned long got_time;
radio.read( &got_time, sizeof(unsigned long) );
// Spew it
printf("Got response %lu, round-trip delay: %lu\n\r",got_time,millis()-got_time);
// Try again 1s later
// Pong back role. Receive each packet, dump it out, and send it back
if ( role == role_pong_back )
// if there is data ready
if ( radio.available() )
// Dump the payloads until we've gotten everything
bool done = false;
while (!done)
// Fetch the payload, and see if this was the last one.
done = radio.read( &got_time, sizeof(unsigned long) );
// Spew it
printf("Got payload %lu...",got_time);
// Delay just a little bit to let the other unit
// make the transition to receiver
delay(20);
// Send the final one back.
radio.write( &got_time, sizeof(unsigned long) );
printf("Sent response.\n\r");
// Now, resume listening so we catch the next packets.
// Change roles
if ( Serial.available() )
char c = toupper(Serial.read());
if ( c == 'T' && role == role_pong_back )
printf("*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK\n\r");
// Become the primary transmitter (ping out)
role = role_ping_out;
else if ( c == 'R' && role == role_ping_out )
printf("*** CHANGING TO RECEIVE ROLE -- PRESS 'T' TO SWITCH BACK\n\r");
// Become the primary receiver (pong back)
Now the error I get is that in the preamble that the arduino prints to the serial monitor, I get only zero-adress. In the maniacBug tutorial it means that the wiring is incorrect, but I checked it many and many times, redoing it from the beginning for many times.
I'm not soldering wires, I'm using the pinned wires of the "arduino prototyping kit" (just to be understandable, I have not the kit unfortunately)
Any Ideas?
Any help?
Thank you for your time.
