Using NXShield library without NXShield hardware
Hi all,
I'm relatively new to Arduino with minor experience with C++.
I've been trying to connect my Lego Mindstorm NXT to a computer via Arduino, and I found these while I was searching:
However, whenever I am trying to execute any of the example codes given in "arduino-libraries", it prompts the following error:
ERROR: Device-ID or Version mismatch. Device-ID: , Version:
Here's one of the example code given in the library:
*  Matthew Richardson
*  matthewrichardson37<at>gmail.com
*  http://mattallen37.wordpress.com/
*  Initial date: Nov. 04 2011
*  Last updated: Apr. 17 2012
*  You may use this code as you wish, provided you give credit where it's due.
*  This is an example program to demonstrate the Lego Sound Sensor drivers of the NXShield Lego Arduino Drivers suite.
*  For NXTSound_driver version 1.2
#include <Wire.h>
#include <NXShield.h>
#include <NXTSound_driver.h>
// declare the NXShield(s) attached to your Arduino.
NXShield    nxshield;
// declare the i2c devices used on NXShield(s).
ClassNXTSound sound;
// String to store messages to send to terminal
char str[256];
  // Initialize the protocol for NXShield
  nxshield.init( SH_SoftwareI2C );   //Software or
//  nxshield.init( SH_HardwareI2C );   //Hardware I2C
  // Initialize the i2c sensors.
  sound.init( &nxshield, SH_BBS1 );
  // Wait until user presses GO button to continue the program
  Serial.println ("Press GO button to continue");
	nxshield.waitForButtonPress(BTN_GO);
// variables to store sensor values
int  soundLevel;
  if(nxshield.getButtonState(BTN_LEFT)){
    sound.SetDB();
  else if(nxshield.getButtonState(BTN_RIGHT)){
    sound.SetDBA();
  soundLevel = sound.SoundLevel();                         // Read Gyro rotation
  sprintf (str, "NXT Sound: %4.d", soundLevel); // format
  Serial.println(str);                                      // send
  delay(50);
FYI, the program does compile, and prints the forementioned error in the monitor after the line   nxshield.init( SH_SoftwareI2C );, but I have no idea how to debug this.
I've seen some resources for the "proper" way of using this class library (with the hardware), but for my purpose, I couldn't find any information regarding this matter.
If anyone had tried this class library before, and knows how to fix this, I would appreciate your help.
Thank you in advance.
I'm not sure what part of "I can't talk to the hardware that doesn't exist" you don't understand.
A link to the hardware you are, and are not, using would be good.
An explanation of why you are using a shield that supports specific hardware, without that hardware, would also be interesting.
I am not currently using any NXShield hardware, since I already own Lego Mindstorm NXT brick (and other components).
If I understood correctly, Dexter Industries has described the forementioned "arduino-libraries" that it can be used to connect NXT and Arduino in his blog:
It don't believe this "arduino-libraries" class library supports specific NXShield hardware, since its own class library already exists.
