using oled display with ardunio
I have used the oled example ( small_ oled ) as it is to write sucessfuly to a ssd1306 display. the program worked well with out any problems. I then modifed the program to add an additional screen and the display never showed the first screen but showed the second screen. I added a long ( 5000) delay, still did not show the first screen. increasing the delay never showed the first screen. I inserted print statements and monitored the running of the program. the print statements showed the program to be working through the first screen write but the information never appeared on the screen.
orignal small _oled that workes
Serial.print( "start");
display.display ();
// Clear the display
display.clearDisplay();
//Set the color - always use white despite actual display color
display.setTextColor(WHITE);
//Set the font size
display.setTextSize(1);
//Set the cursor coordinates
display.setCursor(0,0);
display.print(" test @ size 1");
Serial.println ("running");
display.setCursor(0,10);
display.print (" its working");
display.setCursor(0,20);
display.print (" like it should");
display.startscrollleft(0x00, 0x00);
delay(2000);
display.stopscroll();
modified program (small _oled2)
// display.display ();
delay (2000);
//Set the font size
display.setCursor(0, 0);
Serial.println (" 1 running");
display.setCursor(0, 10);
display.setCursor(0, 20);
delay (1000);
//Set the font size
//set the cursor coordinates
display.print(" test #2");
Serial.println ("2 running");
delay (10000);
display.print (" it also works");
Is there any one who can explain why this does not work
thanks
Wachk
Suggest you read the post at the top of the forum with the title;
How to use this forum - please read
It will tell you how to psot your code so it is easy to read.
Not much point in posting fragments of code that cannot work, because they are incomplete, the problem with the code might well be in the bit you dont post, so post complete code.
