Using one button for two different things?
Hello and thanks for reading this!
I am working on a drink maker and I am trying to make a gui with an lcd and rotary encoder to select how much liquid you want and I need to code with 2 of these one for one liquid and one for another but I want to use one button to send the amount of liquid you want on both off them to the arduino but I don’t know how to do this with one button here is the code:
LiquidCrystal_I2C lcd (0x27, 16, 2);
const int clk = 2;
const int dt = 3;
int counter = 0;
int currentStateclk;
int lastStateclk;
int pumpTime = 0;
const int pump = 7;
const int button = 6;
int buttonstate = 0;
const int led = 5;
const int mixer = 4;
int eight = 8;
  pinMode(clk, INPUT);
  pinMode(dt, INPUT);
  pinMode(led, OUTPUT);
  pinMode(button, INPUT);
  pinMode(8, INPUT);
  lcd.init();
  lastStateclk = digitalRead(clk);
  eight = digitalRead(8);
  pumpTime = counter / 10;
  buttonstate = digitalRead(button);
  if (eight == HIGH)
    currentStateclk = digitalRead(clk);
    if (currentStateclk != lastStateclk  && currentStateclk == 1)
      if (digitalRead(dt) != currentStateclk);
        counter --;
        counter = counter - 4;
        if (counter < 0)
          counter = 0;
      counter ++;
      counter = counter + 4;
      if (counter > 1000)
        counter = 1000;
  lcd.setCursor(1, 0);
  lcd.backlight();
  lcd.print("How much do you want?");
  lcd.setCursor(2, 1);
  lcd.print(counter);
  if (buttonstate == HIGH && pump == LOW)
    digitalWrite(pump, HIGH);
    delay(pumpTime);
    digitalWrite(pump, LOW);
    delay(5000);
    lcd.clear();
  lcd.print(counter);
  delay(2000);
  //code needed here
Please post your code rather than attaching it as it makes it easier to copy it to an editor for examination
Please follow the advice on posting code given in Read this before posting a programming question
In particular note the advice to Auto format code in the IDE and to use code tags when posting code here as it prevents some combinations of characters in code being interpreted as HTML commands such as italics, bold or a smiley character, all of which render the code useless
It said it was more than 9000 characters
Not when I did it. You must have done something wrong
const int clk = 2;
const int dt = 3;
int counter = 0;
int lastStateclk;
int pumpTime = 0;
const int pump = 7;
const int led = 5;
int eight = 8;
  pinMode(dt, INPUT);
  pinMode(8, INPUT);
  lcd.init();
  if (eight == HIGH)
        counter --;
        if (counter < 0)
          counter = 0;
      counter ++;
      if (counter > 1000)
        counter = 1000;
  lcd.backlight();
  lcd.print(counter);
    delay(pumpTime);
    delay(5000);
    lcd.clear();
  lcd.print(counter);
  delay(2000);
  //code needed here
Well I did copy it from vs code and the text was colored and the background was black so maybe that was the problem?
