Using one button to enter and exit an Interrupt running a while loop
How is it going guys. I am having some trouble wrapping my head around Interrupts and while loops. I am working on a project that involves a BME280 temp sensor, an OLED screen and a rotary encoder. I am able to display temp and humidity values no problem on the screen. But since the OLED screen demands a fillscreenblack followed by some kind of delay (same with the BME280) and the rotary encoder needs to be interrupt based. That's fine and I thought I understood this quite well until now. See what I would like to do is press the button on the encoder to enter a menu and display different options. I was thinking of using an interrupt to enter a while loop where I could display the menu options and then press the button again and break from the while loop and get back to the main void loop. But I cant seem to wrap my head around this concept. Maybe I am thinking about interrupts all wrong, I am not sure, but I dont see why I could not do this. So not to upload quite a bit of code I made a little test environment with a button and an LED. When I press the button the interrupt activates the while loop. This causes the LED blink, but for the life of me I cant figure out how to press the button again to get out. Here is the code let me know what you think. The code as it stands blinks once but I have been trying all sorts of ways to make it behave as described. Sorry for the long read ! Thanks !!
const byte ledPin = 13;
const byte interruptPin = 2;
volatile byte state = LOW;
volatile int flag = 0;
volatile int buttonState = 0;
  pinMode(ledPin, OUTPUT);
  pinMode(interruptPin, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(interruptPin), blink, CHANGE);
void blink() {
  while(flag == 0){
    buttonState = digitalRead(interruptPin);
    if (buttonState == LOW){
      flag = 1;
    else{
      digitalWrite(ledPin, HIGH);
      delay(50000);
      digitalWrite(ledPin, LOW);
      delay(50000);
delay() and serial I/O depend on interrupts, and do not work in an interrupt routine.
You should avoid using interrupts for now. If you learn to code without using delay(), it is no problem to do several things and still read a button. See the BlinkWithoutDelay and the "How to do several things at the same time" examples.
Thanks for the heads up ! This new way of thinking should solve all my problems!
