I have an Arduino Elegoo Uno R3 and a Vsionic keypad with multiple user codes. I was wondering if there was a way to program it so each user code unlocked a different cabinet via magnetic lock?
I've successfully used a single keypad for a single lock, but google isn't really helping me figure this out, possibly due to vague wording on my part.
Any help in the right direction would be greatly appreciated. Thanks!
Sorry for not bothering to dig up particulars on your keypad but if it's just a keypad entering a code, it should be quite simple to open different things depending on the code entered, something in the lines of:
if (code = "1234") unlockCabinetOne();
if (code = "2345") unlockCabinetTwo();
if (code = "666") unlockHell();
Great! I was hoping it'd be as simple as that, but I hadn't found anything to support it. That makes my life so much easier.
can you be a bit more specific with the answer ?
i want to do the same but am not handy in the code
heres what i got (borrowed) so far
#include <Password.h> //http://playground.arduino.cc/uploads/Code/Password.zip //tells to use password library
#include <Keypad.h> //http://www.arduino.cc/playground/uploads/Code/Keypad.zip //tells to use keypad library
#include <Servo.h> //tells to use servo library
Servo myservo; //declares servo
Password password = Password( "0000" ); //password to unlock, can be changed
const byte ROWS = 4; // Four rows
const byte COLS = 4; // columns
// Define the Keymap
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = { 9, 8, 7, 6 };// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
byte colPins[COLS] = { 5, 4, 3 };
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
Serial.write(254);
Serial.write(0x01);
delay(200);
pinMode(11, OUTPUT); //green light
pinMode(12, OUTPUT); //red light
myservo.attach(13); //servo on digital pin 9 //servo
keypad.addEventListener(keypadEvent); //add an event listener for this keypad
void loop(){
keypad.getKey();
myservo.write(0);
//take care of some special events
void keypadEvent(KeypadEvent eKey){
switch (keypad.getState()){
case PRESSED:
Serial.print("Enter:");
Serial.println(eKey);
delay(10);
Serial.write(254);
switch (eKey){
case '*': checkPassword(); delay(1); break;
case '#': password.reset(); delay(1); break;
default: password.append(eKey); delay(1);
void checkPassword(){
if (password.evaluate()){ //if password is right open
Serial.println("Accepted");
Serial.write(254);delay(10);
//Add code to run if it works
myservo.write(150); //deg
digitalWrite(11, HIGH);//turn on
delay(5000); //wait 5 seconds
digitalWrite(11, LOW);// turn off
}else{
Serial.println("Denied"); //if passwords wrong keep locked
//add code to run if it did not work
myservo.write(0);
digitalWrite(12, HIGH); //turn on
delay(500); //wait 5 seconds
digitalWrite(12, LOW);//turn off
Please at least format your code halfway decent before posting - it's a mess and hard to read now. The autoformat function of the IDE goes a long way to get brackets at the right indentation and so.
Next: please explain what this code does, and how this is different from what you want it to do.
