I am trying to start a timer at the start of the code. Once this timer is finished it will start a second timer and be able to repeat this process over and over again.
The first timer is a delay till an output is turned on and the second timer is for how long the output will say on.
The code I have so far is below. Any help would be much appreciated!
#include <millisDelay.h>
int LED = 2;
const unsigned long DELAY_TIME = 10000;
const unsigned long DELAY_TIME1 = 2000;
millisDelay moisture_timer;
millisDelay moisture_on;
for (int i = 5; i > 0; i--) { // just to give a little time before it all starts
Serial.print(i); Serial.print(' ');
pinMode(2, OUTPUT);
digitalWrite(2, LOW);
moisture_timer.start(DELAY_TIME);
if (moisture_timer.justFinished()) {
moisture_on.start(DELAY_TIME1);
digitalWrite(2, HIGH);
if (moisture_on.justFinished()) {
int LED = 2;
unsigned long moisture_timer, moisture_on;
pinMode(LED, OUTPUT);
digitalWrite(LED, LOW);
moisture_timer = moisture_on = millis();
if (millis()-moisture_timer> DELAY_TIME) {
if(digitalRead(LED)==LOW){
digitalWrite(LED, HIGH);
if (millis()-moisture_on> DELAY_TIME1) {
moisture_timer = millis();
