Using one-wire DS18B20 sensors as simple id chips, what is the fastest method?
I'm using some DS18B20 temperature sensors as ID's for devices since they're cheaper than the DS2401 (weird but they are).
Two questions...
Is it faster to poll a know list of ID's to see if they're there, or use the search method?
What is the fastest way to check if a sensor is there, for a known ID?
Cheers,
Woody
There are plenty of Address finder scripts already written out there. Just use one that suits your needs and speed
The 1-Wire search method has an ingenious way to find the sensors. I prefer a search with the Arduino OneWire library. You can test the time it takes yourself :wink: I don't know if someone has tested that.
Here is one or two
http://www.hobbytronics.co.uk/ds18b20-arduino
https://playground.arduino.cc/Learning/OneWire
You can also connect it in parasitic mode to reduce wires
