Using or statements within switch statements
I have been writing code for a Morse code flasher. In on section of the code I have it so that the serial monitor will take a capital or lowercase letter. The problem is that it gives me an error of duplicate case value. Is it not possible to use or statements within a switch statement like this.
case 'a'|| 'A' : Serial.println ('a'); dot(); dash(); letterspace(); break;
Mecatronicsstudent: The problem is that it gives me an error of duplicate case value. Is it not possible to use or statements within a switch statement like this.
What you want to do is something like this
switch (var) {
    case 'a':
    case 'A':
      //do something when var equals a/A
    case 'b':
    case 'B':
      //do something when var equals b/B
    default:
      // if nothing else matches, do the default
      // default is optional
Of course what you should really do is study the code that was posted in your other thread by liudr.
Hope this helps,
Brad.
thanks. I will look at the other code as well.
