Using outputs on mega
hi all im new to this forum im wanting some help and advice if possible iv got a mega and want to use all outputs to controlled via 1 input
soon as input is trigger the outputs will start switching on 1 by 1
Give us more information of exactly what you want?
something like this?
  pinMode(2, INPUT);
  for (int i=3; i< 45; i++) pinMode(i, OUTPUT);
  for (int i=3; i< 45; i++) digitalWrite(i, digitalRead(2) );
Hi sorry basically I’m looking to activate using 1 input and all the outputs go on one by one a second or so apart
Add delay(1000); after the for loop that robtillaart gave. Define "go on"?
Soon as 1 input is triggered via a relay contact from my firing box all the outputs will turn on 1 after another with a few second gap between
Change:
To
for (int i=3; i< 45; i++) digitalWrite(i, LOW );
However, they will stay low for ever, unless you add some code to turn them high.
madbiker2012: Hi sorry basically I'm looking to activate using 1 input and all the outputs go on one by one a second or so apart
The demo several things at a time shows how to time things without using delay() because delay() paralyzes the Arduino until the time is up.
This Thread Planning and Implementing a Program may also be of interest.
I suspect your project has more to it than simply making 20 or 30 I/O pins go HIGH at 1 second intervals and stay high forever. It would help if you give us the full picture. Maybe there is a better approach.
...R
Hi thank you for everyone trying to help
It's going to be used as a firework mine sequence press the button once the input has been trigger it will start to fire e-matches from all the outputs 1 after another
madbiker2012: It's going to be used as a firework mine sequence press the button once the input has been trigger it will start to fire e-matches from all the outputs 1 after another
That sounds like it really does only need to run once. And if so it would make perfect sense to use delay() between the steps to give the correct timing.
...R
while (digitalRead (TRIGGER) == HIGH)   // or LOW depending on how you wired things up
  {  }  // wait for trigger
for (int i = 3; i < 20; i++)
  digitalWrite (i, HIGH);
  delay (1000);
@madbiker2012
Have you thought about how to handle the start of the Arduino? e.g. to be sure that you need more than one signal before start?
so you get some state sequence like
SAFE - (special code e.g. 5 second keypress of 2 buttons OR electric lock with key) - ARMED - (push button) - FIRE
instead of
