Using PanasonicIRSensor code to manipulate servos
Hello, I am in the midst of a project to try and create a bot that is controlled by the ir sensor. I want the ir sensor to dictate whether the bot simply runs forward, or if it stops, turns, and tries forward again. How would I be able to do that? I have tried with a simple if else statement in the void loop, but it does not seem to work. Let me know any advice you guys have as I am very very new. Thank you!
#define irLedPin 13 // IR Led on this pin
#define irSensorPin 8 // IR sensor on this pin
#include <Servo.h>
Servo servoLeft;
int irRead(int readPin, int triggerPin); //function prototype
servoLeft.attach(2);
pinMode(irSensorPin, INPUT);
pinMode(irLedPin, OUTPUT);
// prints title with ending line break
Serial.println(“Program Starting”);
// wait for the long string to be sent
delay(100);
Serial.println(irRead(irSensorPin, irLedPin)); //display the results
delay(10); //wait for the string to be sent
int value = ; //don’t really know which variable to use, as none seem to work
if ( value = 1)
servoLeft.write(0);
servoLeft.write(180);
int halfPeriod = 13; //one period at 38.5khZ is aproximately 26 microseconds
int cycles = 38; //26 microseconds * 38 is more or less 1 millisecond
int i;
for (i=0; i <=cycles; i++)
digitalWrite(triggerPin, HIGH);
delayMicroseconds(halfPeriod);
digitalWrite(triggerPin, LOW);
delayMicroseconds(halfPeriod - 1); // - 1 to make up for digitaWrite overhead
return digitalRead(readPin);
But, god forbid that you actually understand what these functions are doing. Why not store the output from the irRead() function into a variable, and print, and use, that variable?
#include <Servo.h>
Servo servoLeft;
  Serial.println("Program Starting");
  delay(100);
  int value =irRead(irSensorPin, irLedPin) ;
  if ( value == HIGH)
    servoLeft.write(0);
 Serial.println(value); //display the results
 digitalWrite(irLedPin, LOW);
delay(200);
    return (digitalRead(readPin));
