Hello,
I'm making a robot that needs to go in a straight line. For that I'm using :
- Arduino UNO
- 2 DC motors
- 2 encoders
I've written the code with PID but I don't know how to convert the speed into a voltage. Anyone can help me?
Here's my code :
#include <PID_v1.h>
#define encoder1 2
#define encoder2 3
#define motor1a 9
#define motor1b 6
#define motor2a 7
#define motor2b 5
byte tension1 = 180;
byte tension2 = 180;
long newposition1;
long oldposition1;
long newposition2;
long oldposition2;
long newtime;
long oldtime;
volatile int num1 = 0;
volatile int num2 = 0;
float speed1;
float speed2;
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
double Kp=?, Ki=?, Kd=?;
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
pinMode(encoder1,INPUT_PULLUP);
pinMode(encoder2,INPUT_PULLUP);
pinMode(motor1a,OUTPUT);
pinMode(motor1b,OUTPUT);
pinMode(motor2a,OUTPUT);
pinMode(motor2b,OUTPUT);
attachInterrupt(digitalPinToInterrupt(2),count1,FALLING);
attachInterrupt(digitalPinToInterrupt(3),count2,FALLING);
SetOutputLimits(?);
SetSampleTime(100);
Setpoint = speed1;
Input = speed2;
myPID.SetMode(AUTOMATIC);
analogWrite(motor1a,tension1);
analogWrite(motor2a,tension2);
newposition1 = num1;
newposition2 = num2;
newtime = millis();
speed1 = (newposition1-oldposition1)/(newtime-oldtime);
speed2 = (newposition2-oldposition2)/(newtime-oldtime);
Serial.print("speed1=");
Serial.print(speed1);
Serial.print("speed2=");
Serial.print(speed2);
oldposition1=newposition1;
oldposition2=newposition2;
oldtime=newtime;
Input = speed2;
myPID.Compute();
speed2 = Output;
if (speed2 < speed1) {
tension2 = tension2 + 1;
else if (speed2 > speed1) {
tension2 = tension2 - 1;
else {
tension2 = tension2;
void count1() {
num1 = num1 + 1;
void count2() {
num2 = num2 + 2;
