Using PID to call (boolean) functions - Hit the gas or simply coast
I need to keep a rolling object at the top/center of a convex surface/circle (Setpoint = (radius of 0). I only have two functions: “Move-Towards-Center” and “Do-Nothing” (“Do-Nothing” lets gravity pull the object away from center, lets momentum keep the object moving, or (target) temporarily stabilize the object at the center).
I would like to use PID to call “Move-Towards-Center” when the Radius exceeds (say) 10%-off, but I would like PID to calculate and call “Do-Nothing” before the object returns and over-shoots the center. This is what PID does best.
Using an MPU-6050 gyro - My code amazingly calculates “radius” (distance from center) and determines location on one of eight areas around the center (which is required by the “Move-Towards-Center” function).
HELP!!! Can PID call functions as Output? If yes, how? If they do - how are boolean decisions made?
And BTW - Are functions simply "int function-name(int x, inty){some action;}
Thank you - Mark
#include "Wire.h" // This library allows you to communicate with I2C devices
#include <Servo.h>
#include <PID_v1.h>  //This library is the PID decision maker
const int MPU_ADDR = 0x68; // I2C address of the MPU-6050. If AD0 pin is set to HIGH, the I2C address will be 0x69.
int16_t gyro_x, gyro_y, gyro_z;      // variables for gyro raw data
int nozzle; //variable for direction
double radius;
char tmp_str[7]; // temporary variable used in convert function
char* convert_int16_to_str(int16_t i) { // converts int16 to string. Moreover, resulting strings will have the same length in the debug monitor.
  sprintf(tmp_str, "%6d", i);
  return tmp_str;
  // PID variables
double Setpoint, Input, Output;
double Kp=4;
double Ki=0.2;
double Kd=1;
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
int WindowSize = 5000;
unsigned long windowStartTime;
  Wire.begin();
  Wire.beginTransmission(MPU_ADDR); // Begins a transmission to the I2C slave (GY-521 board)
  Wire.write(0x6B); // PWR_MGMT_1 register
  Wire.write(0); // set to zero (wakes up the MPU-6050)
  Wire.endTransmission(true);
  //initialize PID variables
  Input = radius;
  Setpoint = 0;
  myPID.SetMode(AUTOMATIC);
  windowStartTime = millis();
  myPID.SetOutputLimits(0, WindowSize);
  Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H) [MPU-6000 and MPU-6050 Register Map and Descriptions Revision 4.2, p.40]
  Wire.endTransmission(false); // the parameter indicates that the Arduino will send a restart. As a result, the connection is kept active.
  Wire.requestFrom(MPU_ADDR, 7*2, true); // request a total of 7*2=14 registers
  // "Wire.read()<<8 | Wire.read();" means two registers are read and stored in the same variable
  gyro_x = Wire.read()<<8 | Wire.read(); // reading registers: 0x43 (GYRO_XOUT_H) and 0x44 (GYRO_XOUT_L)
  gyro_y = Wire.read()<<8 | Wire.read(); // reading registers: 0x45 (GYRO_YOUT_H) and 0x46 (GYRO_YOUT_L)
  gyro_z = Wire.read()<<8 | Wire.read(); // reading registers: 0x47 (GYRO_ZOUT_H) and 0x48 (GYRO_ZOUT_L)
  // Use X and Y data to determine location 1-8 around center of circle
if ((gyro_y>2.4145*gyro_x) && (gyro_y>=-2.4145*gyro_x)) {
    location = 1;
else if ((gyro_y<-2.4145*gyro_x) && (gyro_y>=-.41416*gyro_x)) {
    location = 2;
else if ((gyro_y<-.41416*gyro_x) && (gyro_y>=.41416*gyro_x)) {
    location = 3;
else if ((gyro_y<.41416*gyro_x) && (gyro_y>=2.4145*gyro_x)) {
    location = 4;
else if ((gyro_y<2.4145*gyro_x) && (gyro_y<=-2.4145*gyro_x)) {
    location = 5;
else if ((gyro_y>-2.4145*gyro_x) && (gyro_y<=-.41415*gyro_x)) {
    location = 6;
else if ((gyro_y>-.41415*gyro_x) && (gyro_y<=.41415*gyro_x)) {
    location = 7;
else if ((gyro_y>.41416*gyro_x) && (gyro_y<=2.4145*gyro_x)) {
    location = 8;
radius = sqrt(sq(gyro_x)+sq(gyro_y));    //My Arduino attempt at Pythagoras' Theorem
  // print out data
  Serial.print(" | gX = "); Serial.print(convert_int16_to_str(gyro_x));
  Serial.print(" | gY = "); Serial.print(convert_int16_to_str(gyro_y));
  Serial.print(" | Location = "); Serial.print(location);
  Serial.print(" | Radius = "); Serial.print(radius);
// PID loop data - output must be "Move-Towards-Center" and "Do-Nothing"
Input = radius;
myPID.Compute();                        // Will this compute "Move-Towards-Center" vs "Do-Nothing"?
if (Output = WindowSize){
  Move-Towards-Center;
if (Output = 0){
  Do-Nothing;
  // delay
  delay(100);
I would like to use PID to call "Move-Towards-Center" when the Radius exceeds (say) 10%-off,
How much is 10 % off of 0?
Keeping something balance on top of something with a radius of 0 is going to be very difficult.
So, I suspect that your first paragraph needs some work before your post makes any sense.
