Using pin 2 and 3 as digital I/O
I have designed a custom board using the Atmega328 from Sparkfun. It "talks to other hardware using a latched parallel port or register. All seems well except for bit0 and bit1 appear stuck. I realize they are RX and TX on an Arduino, but I know they can be used as digital I/O also.
Some googling and forum searching suggested the command UCSR0B = 0; Is this the proper command to allow use of pin 0 and 1 on a 328.
It doesn’t appear to work.
 Created:	8/17/2016 9:20:54 AM
 Author:	121776
// Choose a valid PinChangeInterrupt pin of your Arduino board
//this works on the arduino board - not on the pcb - int to fast
// TEST WITH ADDED LATCH 74LS74 - WORKED 8/12
// added alt serial to debug read reg 8/15 tx now on pin 9
/* this routine is meant to verify recent addition of  u18 latch. This latch catches a writeto Base + 0 or base +2
 and is reset by a read of the same port.
 /*this worked on 8/22 with the exception of a stuck bit
 TX is on pin 15 for this code.
#include <AltSoftSerial.h>
#include <SPI.h>
#include <AH_MCP320x.h>
#include "PinChangeInterrupt.h"
// AltSoftSerial always uses these pins:
// Arduino Uno        tx 9         rx 8
// #define PC3  A3
#define busWrtADC A5
#define busWrtDAC A4
#define MISO 12				//pin 18
#define MOSI 11				// pin 17
# define SCK 13				//pin 19
# define dac_sel 8			// pin 14
// # define adc0_select 9			// pin 15
# define adc1_select 10			// pin 16
//# define led 13				//Uno not std  board
//# define pc0 A0				//REG SELECT PINS
//# define pc1 A1
//# define pc2 A2
//# define LATCH A3				//REG strobe
const byte DAC_REF_INT = 8;		//dac definitions
const byte DAC_UPDATE = 3;
const byte FILLER = 0;
const byte DACLO = 0;			//PC0, PC1, PC2 read
const byte DACHI = 1;			//PC0, PC1, PC2 read
const byte  Enable_INT_REF = 1;	// for enable
const byte ADCMD = 2;
const byte DESEL = B0111;
const byte SEL_EN = B0000;
const byte OBF = 1;                 // output buffer full status
const byte adcmdreg = 0;			//PC0, PC1, PC2 read
const byte adchireg = 1;			//PC0, PC1, PC2 write
const byte adcloreg = 0;			//PC0, PC1, PC2 write
const byte adc_status_reg = 5;		//PC0, PC1, PC2 write
const byte  REG_SELECT = 3;
//SoftwareSerial mySerial = SoftwareSerial(rx, tx);
volatile char  adc_cmd_reg_data = 0;		//used in int
volatile int dac_low_reg_data = 0;
volatile int  dac_hi_reg_data = 0;
volatile byte adc_status = 0;
volatile byte dac_status = 0;
int previous = 0;
AH_MCP320x ADC_SPI(10);
AltSoftSerial altSerial;
/*************************************** prototypes  *****************************************************/
byte micro_rd_data_reg(byte reg);
void micro_wrt_data_reg(byte reg, byte wrt_value);
/*************************************** setup *****************************************************/
	UCSR0B = 0;											//allow use of pins 0, 1
	altSerial.begin(9600);
	pinMode(busWrtADC,INPUT);
	pinMode(busWrtDAC,INPUT);
/*in,in,out.out,out,out									select no ports  U6 (7 n/c
																enable hardware selection  U6
																power up set to enable select addr 7 - 0-6 high */
	DDRC = B001111;
	PORTC =  DESEL;
	DDRD = B00000000;
	// Attach the new PinChangeInterrupt and enable event function below
	attachPCINT(digitalPinToPCINT(busWrtADC), adc, RISING);
	attachPCINT(digitalPinToPCINT(busWrtDAC), dac, RISING);
	altSerial.println("Analog board online   - inttest.ino 8/18");
	if (previous != dac_low_reg_data){
		altSerial.println(dac_low_reg_data,HEX);
		previous = dac_low_reg_data;
	altSerial.print("dac     ");
	altSerial.print(dac_status);
	altSerial.print("        data     ");
	altSerial.print(dac_low_reg_data);
	altSerial.println("");
int micro_rd_data_reg(int reg)          //reads a byte from register specified
	char rd_val = 0;
		DDRD = B00000000;						//set port D 1 to 8 as input
		PORTC = DDRC | reg  | SEL_EN ;						//SELECT PORT
		rd_val = PIND;								// input data
		PORTC = DDRC | DESEL;						//de SELECT PORT
		return rd_val;
void micro_wrt_data_reg(int reg,int value)          //write a  byte to register specified
	byte wrt_val;
	DDRD = B11111111;						//set port D 1 to 8 as output
	PORTC = DDRC | reg | SEL_EN;						//SELECT PORT
	PORTD = wrt_val;
//*********************** interrupt routine*****************************************
void adc(void) {									//PIN 26
		PORTC = DDRC | ADCMD ;
		adc_cmd_reg_data = PIND;				// input data
		++adc_status;
void dac(void)											//PIN 27
	/* this routine is entered when a bus read to Base +0 occurs
	it updates - global  var dac_hi_reg_data and dac_low_reg_data*/
			//PORTC =  DACHI;;
			//dac_hi_reg_data = PIND;				// input data
			PORTC = DACLO;     // select port
			delayMicroseconds(1000);
			dac_low_reg_data = PIND;				// input data
			PORTC = DESEL;					//deselct port
			++dac_status;								// debug
