Using pin declaration with INPUT_PULLUP when working with PCF8574 expander
The laibrary allows following pin declaration when working with PCF8574
pcf8574.pinMode(P2, INPUT_PULLUP);
For me that would indicate existance of built in pullup resistors in PCF8574 chip and I believe that is not the case.
Someone hinted to me that if I declare expander pin this way the internal pullup resistors of Arduino I2C pins is used. But what if I declare all 8 pins on the expande this way.
Can someone clarify this to me.
Please give a link to that library. The PCF8574 Arduino library has no method pinMode().
If you read the related documentation then you'll find:
When using the pins as inputs, the pins are set to HIGH by the MCU, which turns on a weak 100 uA internal pull-up to Vcc.
There is no difference between INPUT and INPUT_PULLUP. The pin is open drain with a pullup current source.
