Using PIND
I’m banging my head because I can’t solve this, yet it seems so simple to me. I’m trying to use PIND to read a byte from port d as digital. After investigating I read you can’t read bits 7 and 8 of port d as digital, yet the atmega328 datastasheet says you can use the whole port. Did I read the datasheet wrong or is this an arduino limitation?
Here is my code:
  Serial.begin(2500000);
  DDRD = B00000000;
  Serial.print(PIND, BIN);
  Serial.print ("\n");
  Serial.print(digitalRead(14), BIN);
  Serial.print(digitalRead(15), BIN);
  Serial.print(digitalRead(16), BIN);
  Serial.print(digitalRead(17), BIN);
  Serial.print(digitalRead(18), BIN);
  Serial.print(digitalRead(19), BIN);
  Serial.print(digitalRead(20), BIN);
  Serial.print(digitalRead(21), BIN);
Output (as I bring each pin high):
11
10000000
11
01000000
11
00100000
11
00010000
11
00001000
11
00000100
As you can see, digitalread works as expected, but it seems PIND always is 00000011.
Furthermore, I tried to enable the internal pullups with PORTD = B11111111; The pullups don’t seem to work, but I get:
11111111
10000000
11111111
01000000
11111111
00100000
11111111
00010000
11111111
00001000
11111111
00000100
Any ideas? Thanks.
I think you are getting AVR PORTS Vs Arduino pin numbers mixed up.
Your using Arduino pin numbers 14-21 (of which 20 & 21 are not avalible) which belong to PORTC not PORTD, so you are comparing different ports in your printing statements. PORTD covers Arduio pin numbers 0-7.
Lefty
Oh... I knew it was something stupid like that. It's working now. Thanks a lot Lefty.
