Using pointers to get diagnostic info from two stepper motors (starting from program using one)
Original:
My attempt:
#include <TMC2209.h>
HardwareSerial &serial_stream_1 = Serial3; // Connect to the first TMC2209
HardwareSerial &serial_stream_2 = Serial2; // Connect to the second TMC2209
const int DELAY = 2000;
// Instantiate TMC2209 for the first motor driver
TMC2209 stepper_driver_1;
// Instantiate TMC2209 for the second motor driver
TMC2209 stepper_driver_2;
  // Initialize the first TMC2209 motor driver
  stepper_driver_1.setup(serial_stream_1);
  // Initialize the second TMC2209 motor driver
  stepper_driver_2.setup(serial_stream_2);
  // Perform initial setup for both motor drivers
  setupMotorDriver(stepper_driver_1);
  setupMotorDriver(stepper_driver_2);
  // Control the first motor driver (stepper_driver_1)
  Serial.println("First Motor Driver:");
  moveMotor(stepper_driver_1, 1000); // Move the first motor
  // Add more control code for the first motor driver here
  // Control the second motor driver (stepper_driver_2)
  Serial.println("Second Motor Driver:");
  moveMotor(stepper_driver_2, -1000); // Move the second motor
  // Add more control code for the second motor driver here
  // Query and print the status and settings for both motor drivers
  queryStatusAndSettings(stepper_driver_1, "First Motor Driver");
  queryStatusAndSettings(stepper_driver_2, "Second Motor Driver");
  delay(DELAY);
void setupMotorDriver(TMC2209 &driver)
  // Configure motor driver settings for each driver here
  TMC2209::Settings settings;
  // Example configuration (you can customize these settings)
  settings.stealth_chop_enabled = true;
  settings.microsteps_per_step = 64;
  settings.ihold_register_value = 0x0F; // Adjust current settings as needed
  settings.automatic_current_scaling_enabled = true;
  settings.automatic_gradient_adaptation_enabled = true;
  settings.pwm_offset = 4;
  settings.pwm_gradient = 3;
  settings.cool_step_enabled = true;
  settings.analog_current_scaling_enabled = false;
  settings.internal_sense_resistors_enabled = false;
  // Set the motor driver settings
  driver.setStealthChopEnabled(settings.stealth_chop_enabled);
  driver.setMicrostepsPerStep(settings.microsteps_per_step);
  driver.setIHoldRegisterValue(settings.ihold_register_value);
  driver.setAutomaticCurrentScalingEnabled(settings.automatic_current_scaling_enabled);
  driver.setAutomaticGradientAdaptationEnabled(settings.automatic_gradient_adaptation_enabled);
  driver.setPWMOffset(settings.pwm_offset);
  driver.setPWMGradient(settings.pwm_gradient);
  driver.setCoolStepEnabled(settings.cool_step_enabled);
  driver.setAnalogCurrentScalingEnabled(settings.analog_current_scaling_enabled);
  driver.setInternalSenseResistorsEnabled(settings.internal_sense_resistors_enabled);
  // Print the updated settings
  printSettings(settings);
void moveMotor(TMC2209 &driver, long steps)
  // Move the motor with the specified number of steps
  driver.setTargetPosition(driver.getPosition() + steps);
  while (!driver.isStandstill())
    // Wait for the motor to reach the target position
void queryStatusAndSettings(TMC2209 &driver, const char *driverName)
  Serial.println("*************************");
  Serial.println(driverName);
  // Query and print the motor driver settings
  driver.copyTo(settings);
  Serial.println("hardwareDisabled()");
  bool hardware_disabled = driver.hardwareDisabled();
  Serial.print("hardware_disabled = ");
  Serial.println(hardware_disabled);
  Serial.println("getStatus()");
  TMC2209::Status status = driver.getStatus();
  printStatus(status);
void printSettings(const TMC2209::Settings &settings)
  Serial.println("Current Motor Driver Settings:");
  Serial.print("settings.stealth_chop_enabled = ");
  Serial.println(settings.stealth_chop_enabled);
  Serial.print("settings.microsteps_per_step = ");
  Serial.println(settings.microsteps_per_step);
  Serial.print("settings.ihold_register_value = ");
  Serial.println(settings.ihold_register_value);
  Serial.print("settings.automatic_current_scaling_enabled = ");
  Serial.println(settings.automatic_current_scaling_enabled);
  Serial.print("settings.automatic_gradient_adaptation_enabled = ");
  Serial.println(settings.automatic_gradient_adaptation_enabled);
  Serial.print("settings.pwm_offset = ");
  Serial.println(settings.pwm_offset);
  Serial.print("settings.pwm_gradient = ");
  Serial.println(settings.pwm_gradient);
  Serial.print("settings.cool_step_enabled = ");
  Serial.println(settings.cool_step_enabled);
  Serial.print("settings.analog_current_scaling_enabled = ");
  Serial.println(settings.analog_current_scaling_enabled);
  Serial.print("settings.internal_sense_resistors_enabled = ");
  Serial.println(settings.internal_sense_resistors_enabled);
void printStatus(const TMC2209::Status &status)
  Serial.println("Current Motor Driver Status:");
  Serial.print("status.over_temperature_warning = ");
  Serial.println(status.over_temperature_warning);
  Serial.print("status.over_temperature_shutdown = ");
  Serial.println(status.over_temperature_shutdown);
  Serial.print("status.short_to_ground_a = ");
  Serial.println(status.short_to_ground_a);
  Serial.print("status.short_to_ground_b = ");
  Serial.println(status.short_to_ground_b);
  Serial.print("status.low_side_short_a = ");
  Serial.println(status.low_side_short_a);
  Serial.print("status.low_side_short_b = ");
  Serial.println(status.low_side_short_b);
  Serial.print("status.open_load_a = ");
  Serial.println(status.open_load_a);
  Serial.print("status.open_load_b = ");
  Serial.println(status.open_load_b);
  Serial.print("status.over_temperature_120c = ");
  Serial.println(status.over_temperature_120c);
  Serial.print("status.over_temperature_143c = ");
  Serial.println(status.over_temperature_143c);
  Serial.print("status.over_temperature_150c = ");
  Serial.println(status.over_temperature_150c);
  Serial.print("status.over_temperature_157c = ");
  Serial.println(status.over_temperature_157c);
  Serial.print("status.current_scaling = ");
  Serial.println(status.current_scaling);
  Serial.print("status.stealth_chop_mode = ");
  Serial.println(status.stealth_chop_mode);
  Serial.print("status.standstill = ");
  Serial.println(status.standstill);
No, it's not working. Litany of errors running on Arduino Mega.
  • 'class TMC2209' has no member named 'setStealthChopEnabled'
  • 'class TMC2209' has no member named 'setIHoldRegisterValue'
  • 'class TMC2209' has no member named 'setAutomaticCurrentScalingEnabled'
Etc.
Yes, the original complies and uploads perfectly.
const int dirPinX = 13;
const int stepPinX = 12;
const int dirPinY = 8;
const int stepPinY = 7;
int resetXcount = 0, resetYcount = 0, stepXcount = 0, stepYcount = 0;
//float deltaTheta = PI/8000;             // Original
float deltaTheta = PI / 8000;             // Adjust this when gear ratio changes
float A = 80;       // Amplitude - scaling (stretching/shifting)
float deltaX = 0, deltaY = 0, theta = 0;
float x_1 = 0, x_2 = 0, y_1 = 0, y_2 = 0;
  pinMode(stepPinX, OUTPUT);
  pinMode(dirPinX, OUTPUT);
  pinMode(stepPinY, OUTPUT);
  pinMode(dirPinY, OUTPUT);
  deltaX  = 0;   //(dirPinX, LOW);  // right
  deltaY  = 0;   //(dirPinY, LOW);  // away
  for (int i = 0; i < 22000; i++)
    stepX();
    stepY();
    digitalWrite(stepPinX, LOW);
    digitalWrite(stepPinY, LOW);
    delayMicroseconds(200);
   *  Move motors function calls
  delay(DELAY);
//  driver.copyTo(settings);
//  printSettings(settings);
void stepX()
  if (deltaX < 0) // Set motor direction clockwise
    digitalWrite(dirPinX, HIGH);
    digitalWrite(dirPinX, LOW);
  digitalWrite(stepPinX, HIGH);
    delayMicroseconds(5);
void stepY()
  if (deltaY < 0) // Set motor direction clockwise
    digitalWrite(dirPinY, HIGH);
    digitalWrite(dirPinY, LOW);
  digitalWrite(stepPinY, HIGH);
Ok, I just took all those settings out and hope the default settings work out. Thanks for help.
No, I wanted 5 us each.
