To make things clear:
I am building a large scale XY Polar plotter for a school demonstration. To achieve this I am using:
Hardware:
Arduino UNO
CNC Shield v3
2x Pololu A4988 drivers
2 x NEMA 17 steppers
LED for ‘spindle’ - to be a relay or similar to control load once operating
Software:
Arduino IDE v1.0.5
Polargraph 1.2
Processing 1.5.1
Configuration:
200 step/rev
16th stepping
As requested:
I have narrowed things down to one section of code: penlift.ino
This is the entire file (note: this is part of a sketchbook including 14 .ino files)
* Polargraph Server. - CORE
* Written by Sandy Noble
* Released under GNU License version 3.
* http://www.polargraph.co.uk
* https://github.com/euphy/polargraph_server_a1
Penlift.
This is one of the core files for the polargraph server program.
This file contains the servo calls that raise or lower the pen from
the page.
The behaviour of the pen lift is this:
If a simple "pen up", or "pen lift" command is received ("C14,END"), then the machine will
not try to lift the pen if it thinks it is already up. It checks the value of the
global boolean variable "isPenUp" to decide this.
If a qualified "pen up" is received, that is one that includes a pen position (eg "C14,150,END"),
then the global "up" position variable is updated, and the servo is moved to that position,
even if it already is "up". Because naturally, if the up position has changed, even if it
is already up, there's a good chance it won't be up enough.
The same goes for the
#ifdef PENLIFT
void penlift_movePen(int start, int end, int delay_ms)
penHeight.attach(PEN_HEIGHT_SERVO_PIN);
if(start < end)
for (int i=start; i<=end; i++)
penHeight.write(i);
delay(delay_ms);
#ifdef DEBUG_PENLIFT
Serial.println(i);
#endif
for (int i=start; i>=end; i--)
penHeight.write(i);
delay(delay_ms);
Serial.println(i);
#endif
penHeight.detach();
void penlift_penUp()
if (inNoOfParams > 1)
Serial.print("Penup with params");
#endif
int positionToMoveFrom = isPenUp ? upPosition : downPosition;
upPosition = atoi(inParam1);
penlift_movePen(positionToMoveFrom, upPosition, penLiftSpeed);
if (isPenUp == false)
penlift_movePen(downPosition, upPosition, penLiftSpeed);//
isPenUp = true;
void penlift_penDown()
// check to see if this is a multi-action command (if there's a
// parameter then this sets the "down" motor position too).
downPosition = atoi(inParam1);
penlift_movePen(positionToMoveFrom, downPosition, penLiftSpeed);
if (isPenUp == true)
penlift_movePen(upPosition, downPosition, penLiftSpeed);
isPenUp = false;
#endif
From what I can tell - If I were to change the following two sub routines from…
#endif
isPenUp = true;
isPenUp = false;
to something like…
digitalWrite(12, LOW);
isPenUp = true;
digitalWrite(12, HIGH);
isPenUp = false;
Where I get lost is how ‘penlift_penUp’ and ‘penlift_penDown’ are called. Also I get lost in the ‘penlift_movePen’ subroutine.
I have tried to make membership on the polargraph site’s forum however there is a problem and I cant make an account sad face
