Using PORTD
Hello, complete newbie and I'm having a problem solving the following:
"A complete 8-bit PORTD is orientated as output. Arduino digital pins are 0-7.
In order to set 2,5,7,4 to a high level (5V), and all the others to a low level (0), we use the command:
PORTD = x;
x = ?"
Sorry if this is the wrong place to ask or if I translated something poorly as English is not my main language, but would really like some help with this :cry:
I think they are asking "What is the numeric value of an 8-bit number that has bits 2, 4, 5, and 7 set (1) and the other bits clear (0).
Remember that bits are numbered in order with 0 being the rightmost/least significant bit and 7 being the leftmost/most significant bit.
you gave us no information about what you know. we can't know what to tell you until you tell us what you know.
PORTD is a row of pins that can be set high or low. it is one byte of memory. if you write a byte to PORTD you set or clear 8 pins simultaneously. PORTD and other ports gives you a way to control 8 ports at once. PORTD works well for controlling an 8 relay module.
If you write a decimal value of 0 to PORTD, you get
PORT: 7 6 5 4 3 2 1 0
DATA: 0 0 0 0 0 0 0 0
If you write a decimal value of 255 to PORTD, you get
DATA: 1 1 1 1 1 1 1 1
If you write a decimal value of 150 to PORTD, you get
DATA: 1 0 0 1 0 1 1 0
a byte set to 10010110 has a decimal value of ( 2 + 4 + 16 + 128 ) = 150.
PORTD = x;
x = ?"
is a very poor way to say
Set PORTD to
DATA: 1 0 1 1 0 1 0 0
which would be expressed in decimal as ( 2 + 4 +16 +32 + 128 ) = 182
so, x = 182
or
just set the value of PORTD with
PORTD == 0b10110100, which is the same value in binary
search term: arduino bit manipulation
Oh I see, thanks for replies and sorry if it was a dumb question (problem solved!)
