Hello,
I recently acquired the Portenta H7 and the Hat Carrier. I followed the tutorial (https://docs.arduino.cc/tutorials/portenta-h7/setting-up-portenta/), and the LED_BUILTIN blinking works fine, but now I would like to test the Push Button (PB1) available on the Hat Carrier, which is connected to GPIO1. The issue is that I can't seem to find the pin number of GPIO1 associated with this button (const int buttonPin = ??). The schematic of the Hat Carrier shows that GPIO1 is connected to pin 48 of the high-density connector J2 (see image below). However, I tested with const int buttonPin = 48 and it doesn't work, so I think the declaration is not that simple. So, I went to find the name of the microcontroller port, which is PC15 (see ABX00042-full-pinout.pdf). Is this what should be used? Thanks in advance for your help!
const int buttonPin = ?; // the number of the pushbutton (PB1) pin connected to GPIO1
int buttonState = 0;
// initialize the LED pin as an output:
pinMode(LED_BUILTIN, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (buttonState == HIGH) {
digitalWrite(LED_BUILTIN, LOW);
digitalWrite(LED_BUILTIN, HIGH);
I should mention, I have not spent much time with the Portenta. I purchased one like you have to see how it compared to the GIGA I have.
With some of the newer boards (maybe mainly MBED boards), it appears like they added two parallel ways to talk to IO pins. The main Arduino way which is by a number, and another way by using logical Pin Names, that which then map through to either calling off with the corresponding Arduino IO pin or go through to use MBED to do the work.
You can see the top level of this code in their cores\Arduino\wiring_digital.cpp file
They use a table that is built into the variant (variant.cpp, which maps pin Numbers to Names (or you can search through table for name, to find the index).
And you mentioned PC15, which in their naming is PC_15... Which is in that table...
Not sure if it is the right pin... Although does match my raw Excel file where I tried to go through and map all of the Connector pins of the Portenta to the underlying H7 processor pins and Arduino IO pins and what functions each of these pins can do...
One page starts off like:
Expand
Arduino
HAT
Standard
Port
AF0
AF1
AF2
AF3
AF4
AF5
AF6
AF7
AF8
AF9
AF10
AF11
AF12
AF13
AF14
AF15
J2-73, J1-34
15/A0
PH01
ANALOG_A0
PA0
TIM2_CH1/ TIM2_ETR
TIM5_CH1
TIM8_ETR
TIM15_BKIN
USART2_ CTS/USAR T2_NSS
UART4_TX
SDMMC2_ CMD
SAI2_SD_B
ETH_MII_ CRS
EVENT OUT
J2-75
16/A1
PH02
ANALOG_A1
PA1
TIM2_CH2
TIM5_CH2
LPTIM3_ OUT
TIM15_ CH1N
USART2_ RTS/ USART2_ DE
UART4_RX
QUADSPI_ BK1_IO3
SAI2_MCLK _B
ETH_MII_ RX_CLK/ ETH_RMII_ REF_CLK
LCD_R2
EVENT OUT
J1-35
13
RPI29
UART1_RX
PA10
TIM1_CH3
HRTIM_ CHC2
LPUART1_ RX
USART1_ RX
FDCAN1_ TXFD_ MODE
OTG_FS_ ID
MDIOS_ MDIO
LCD_B4
DCMI_D1
LCD_B1
EVENT OUT
J1-28
USB D-
PA11
TIM1_CH4
HRTIM_ CHD1
LPUART1_ CTS
SPI2_NSS/ I2S2_WS
UART4_RX
USART1_ CTS/ USART1_ NSS
FDCAN1_ RX
OTG_FS_ DM
LCD_R4
EVENT OUT
J1-26
USB0 D+
PA12
TIM1_ETR
HRTIM_ CHD2
LPUART1_ RTS/ LPUART1_ DE
SPI2_SCK/ I2S2_CK
UART4_TX
USART1_ RTS/ USART1_ DE
SAI2_FS_B
FDCAN1_ TX
OTG_FS_ DP
LCD_R5
EVENT OUT
J1-75
JTAG2
SWDIO
PA13
JTMS/ SWDIO
EVENT OUT
JI-77
JTAG4
SWCK
PA14
JTCK/ SWCLK
EVENT OUT
PA15
JTDI
TIM2_CH1/ TIM2_ETR
HRTIM_FL T1
CEC
SPI1_NSS/ I2S1_WS
SPI3_NSS/ I2S3_WS
SPI6_NSS
UART4_ RTS/UART 4_DE
UART7_TX
DSI_TE
EVENT OUT
And the line for J2-48 shows
J2-48 GPIO_1 PC15 - - - - - - - - - - - - - - - "EVENT
OUT"
And the your sketch, slightly modified appears to work:
const PinName buttonPin = PC_15; // the number of the pushbutton (PB1) pin connected to GPIO1
