Using potentiometer to establish a frequency to flash an LED without delay
I am trying to create a device to flash an LED ( also an electromagnet, and a small speaker) at a known frequency and show that frequency on a LCD display. I believe I have the circuitry worked out and the basic code. It mostly does what I want but it is a little glitchy in terms of; the display seems to have a hard time keeping up at higher frequencies. ie the display flickers and doesn’t print a number. Also I wonder about the accuracy of the number presented as frequency, ie have I done the math correctly.
#include<LiquidCrystal.h>
LiquidCrystal lcd(12,11,5,4,3,2);
int potentiometer=A0;
int potRead = 0;
int redLED = 13;
int isOn = 1;
long now = 0;
void setup(){
pinMode(redLED,OUTPUT);
pinMode(potentiometer,INPUT);
digitalWrite(redLED,HIGH);
void loop(){
potRead = analogRead(potentiometer);
if(millis() > now + potRead){
digitalWrite(redLED,isOn);
isOn = 1 - isOn;
now = millis();
lcd.begin(16,2);
lcd.print(“potValue=”);
lcd.print(potRead);
lcd.setCursor(0,1);
lcd.print(“frequency=”);
lcd.print(1023/potRead);
int nPotPin=A0;
int nLEDPin= 13;
unt32_t nFlashTime = 0, nMillisLastLEDChange = 0;
bool bLEDPinState = false;
void setup(){
  pinMode(nLEDPin,OUTPUT);
  pinMode(nPotPin,INPUT);
  digitalWrite(nLEDPin,HIGH);
  nMillisLastLEDChange = millis();
uint32_t getFrequency(uint16_t nAnalogReading)
    return nAnalogReading * 100; // What ever algorithm you choose
    nFlashTime  = getFrequency(analogRead(nPotPin));
    if (millis() >= (nMillisLastLEDChange + nFlashTime))
         digitalWrite(nLEDPin, bLEDPinState);
         bLEDPinState = !bLEDPinState;
    lcd.begin(16,2);
    lcd.print("potValue=");
    lcd.print(potRead);
    lcd.setCursor(0,1);
    lcd.print("frequency=");
Hi
Save yourself some time and use the inbuilt tone() function
Something like this should work:-
int potRead = 0;
int redLED = 13;
unsigned int flashFreq = 0;
unsigned long now = 0;
const unsigned int minFreq = 100;     // Minimum frequency. Can't go lower than 31hz
const unsigned int maxFreq = 10000; // Maximum frequency. Maximum of 65535Hz
const int updateRate = 100;            // Sets the display update rate 100 equals 10 times a second
void setup(){
  lcd.begin(16,2);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("potValue = ");
  lcd.setCursor(0,1);
  lcd.print("Frequency = ");
void loop(){
  potRead = analogRead(potentiometer);                       // Read the pot
  flashFreq = map(potRead, 0, 1023, minFreq, maxFreq);  // Map it to a frequency
  tone(redLED, flashFreq);                                           // set the output pin oscillating
  if (millis() > (now + updateRate)) {                             // update the display every 100ms
     lcd.setCursor(11,0);
     lcd.print(potRead);
     lcd.setCursor(12,1);
     lcd.print(flashFreq);
     now = millis();
You just assign the minimum and maximum frequencies and the code sorts out everything for you.
Ian
boylesg:
int nPotPin=A0;
int nLEDPin= 13;
void setup(){
   lcd.begin(16,2);
   lcd.print(potRead);
   lcd.setCursor(0,1);
Do you think the code would work better if it compiled ? :slight_smile:
UKHeliBob:
Didn't check it for syntax errors - I figure the OP can do that if they use it.
boylesg:
Not very friendly.
Sometimes it is necessary to provide code that you cannot test due to not having the same hardware, but I do try to compile what I post. Libraries are sometimes a problem, but not in this case.
boylesg:
Didn’t check it for syntax errors - I figure the OP can do that if they use it.
then you should say “here is an attempt (untested, not compiled)”
UKHeliBob:
Not very friendly.
Unfriendly how exactly?
I did take the trouble to suggest some code after all.
I just typed it directly in here rather than in Arduino IDE.
Give me a break man! :confused:
BulldogLowell:
then you should say "here is an attempt (untested, not compiled)"
Will take on board this suggestion in future.
boylesg
Thank you very much!
I am experiencing a little difficulty with your code and couldn't seem to figure out where the problem is. When I attempt to verify I get an error message;
The line just below void loop() is high lighted. "{"
I haven't had time to mess with it today until now. I will consider the other folks input and see if I can make it work.
Thank you IanCrowe, UkHeliBob, and BulldogLowell.
Side note Ian-- I would like to have my lowest frequency be 1 hz--- part of the problem I'm trying to work around.
Thanks,
Rich
Dragonvet:
boylesg
Sorry matey but I typed that code in directly in the reply - did not check it in the compiler.
Give me a moment and I will figure out what I did wrong re syntax.
Here you go the following compiles.
Just a suggestion....a lot of people in here would probably give me a bit of 'stick' for suggesting it but never the less.....consider using the MFC (Microsoft Foundation Classes) coding standard.
I have not come across a better and more helpful standard so I rate it.
For variables it uses a lower case letter that indicates the type of the variable, followed by a descriptive name.
uint8_t nLEDPin.
n denotes that the variable is an integer.
I personally don't bother differentiating integer size (8 bit, 16 bit or 32 bit) but I guess you can modify the the MFC standard if you prefer - n8, n16, n32.
b denotes boolean
c denotes character
str denotes a string - I don't bother differentiating between String objects (String str;)and char arrays (char str[5]) But if you prefer MFC uses sz or lpsz for char arrays and str for its CString objects.
array denotes any array variable like int arrayPins[5]
If you define a class then capital 'C' followed by the class name, e.g. CString This makes it easy to see the difference between a class name and an object name. Consider the confusion for newbies over Arduino's String and string. Compared to my custom string class 'CString' versus string.
And I guess if you have a struct instead of a class then SString.
And so on.
If you see 'nLEDPin' in your code 6 months later then you will IMMEDIATELY know what that variable is for, compared to say just 'LED = ....'
int nPotPin=A0;
int nLEDPin= 13;
uint32_t nFlashTime = 0, nMillisLastLEDChange = 0;
    lcd.begin(16,2);
    lcd.print(nPotPin);
    lcd.setCursor(0,1);
    lcd.print(1023/nPotPin);
Consider if you were looking at your code 12 months later and saw this:
n + p + q
compared to if you saw this
strN + strP + strQ
boylesg, Thanks tons amigo! Your teachings on the lingo really help a lot. I didn't want or expect anyone to write the code for me but I appreciate what you did. It gets so frustrating trying to decipher the code if you aren't from that world. I want to be self sufficient and you are great to provide me some tools. "Teach a man to fish..."
Thanks again!
No worries buddy.
Becoming good at coding just takes patience and determination and lots of practice practice practice.
A couple of other MFC naming conventions…
int *pInt = NULL // Small p for ‘pointer to’
And all data members in class declarations are preceded by m_, for example int m_nPinNum.
The above is really helpful in your class functions for easily distinguishing between class data members and local variables in your class functions.
I have also started using g_ for global variables that you declare outside setup() and loop() etc
