Using print() with spaces between data on 1 line
How can print() be used to print several fields of data on one line, with spaces between each field of data? for instance:
 Serial.print("word1");
  Serial.print("\t");              // prints a tab
  Serial.print("word2");
  Serial.print("\t");
  Serial.print("word3");
  Serial.print("\t");
  Serial.print("word4");
  Serial.print("\t");
  Serial.print("word5");
  Serial.print("\t");
  println()
Will this print a row of words 1 - 5 on one line, with spaces between each word.
What will [u]print("\t");[/u] produce?
Or could one [u]print()[/u] be used in front of the words which are seperated by a colon or a comma? such as:
print("word1", "word2"," word3", "word4", "word5");
println();
PO'T :-?
You can use it like so:
Serial.print(“word1 \t”);
Serial.print(“word2 \t”);
Make sure you add that space, that will work for the space, or you can add another line, just for that space:
Serial.print(“word1”);
Serial.print(" ");
Serial.print(“word2”);
If you use Serial.print alot, you should look into the Streaming library, it’s mighty fancy! lol can turn the above, into pretty much:
Serial << “word1” << " " << “\t” << “word2” << " " <<"\t" << “word3” << endl;
or isntead of endl, original Serial.println();
or of course:
Serial << “word1 \t” << “word2 \t” << “word3 \t” << endl;
And the awesome thing about it… it adds 0 bytes on top of your sketch, it just adds a variation of the “print” library, for Serial.print etc it’s awesome.
Here’s the link, and more examples:
http://arduiniana.org/2009/04/new-streaming-library/
