I'm using processing on a windows 7 machine to send commands to my BlueSmirf modem on my Arduino 0022. Right now I am simply trying to use a keystroke to turn on an LED. The program works fine when I used it on a macbook pro earlier today, but when the commands are coming from my computer there is a 10 second lag in between when I hit the key and when the LED lights up. Has anyone else had problems with this? I wasn't able to find anything on the internet. Thanks.
Isn't the macbook pro a computer? Are we to presume that your computer is NOT a macbook pro? If so, what OS is it running?
What does the Processing sketch look like? What does the Arduino sketch look like? Which model Arduino is the 0022? I've never heard of that model.
i'm running windows 7
the arduino is the nano v3 running the arduino 0022 software...http://www.arduino.cc/en/Main/Software
arduino code:
// global variables
int message = 0; // variable to receive data from the serial port
int ledpin = 8; // LED connected to pin 48 (on-board LED)
//--- Function: Setup ()
pinMode(ledpin, OUTPUT); // pin 48 (on-board LED) as OUTPUT
Serial.begin(9600); // start serial communication at 9600bps
//--- Function: loop ()
if( Serial.available() > 0 ) // if data is available to read
message = Serial.read(); // read it and store it in 'val'
if( message == 'R' ) // if 'R' was received
digitalWrite(ledpin, HIGH); // turn ON the LED
else if (message == 'r')
digitalWrite(ledpin, LOW); // otherwise turn it OFF
delay(100); // wait 100ms for next reading
processing code:
import processing.serial.*; // Load serial library
Serial arduinoPort; // Set arduinoPort as serial connection
//--- Function: setup
//set up windowh
size(200, 200);
noStroke();
// List all the available serial ports in the output pane.
// You will need to choose the port that the Wiring board is
// connected to from this list. The first port in the list is
// port #0 and the third port in the list is port #2.
println(Serial.list());
// Open the port that the Wiring board is connected to (in this case 1
// which is the second open port in the array)
// Make sure to open the port at the same speed Wiring is using (9600bps)
arduinoPort = new Serial(this, Serial.list()[4], 9600);
//--- Function: draws background and rectangles
void draw()
background(255);
//Turn LED on and off if buttons pressed where
//R = on (high) and r = off (low)
if(keyPressed == true)
arduinoPort.write('R');
println("on");
fill(0);
arduinoPort.write('r');
println("off");
fill(255);
rect(25, 25, 50, 50);
astronaut,
Have you had any luck finding out what is up with the delay? I'm running Vista, Arduino Duemilanove, BlueSMiRF silver and having the same issues.
One thing I'd like to note though, is that I don't have any delay issues when I use my Android phone to talk to the Arduino.
I'm thinking that it's on the side of Processing that is having issues.
