Hey everyone, I am currently working on an 8x8x8 LED cube, in which I am using an array of values to determine LED brightness anywhere from 0 -> 255 on each LED so my array would be something like this
byte myanimation[][8][64]
With an undefined amount of frames (first brackets) second is Layer and Third is LED so essentially
myanimation[0][0][63] = 255;
would make First Frame of the animation, Bottom layer of the Cube, last light on.
This works as a 2D array without the Frame dimention only allowing solid images...
I believe the 3D array is not working as 4 Frames, 8 Layers and 64 LEDs as an array is 4*(8*64) = 2048 bytes, pretty much filling up the SRAM I am using the Arduino Uno or possibly NANO for this project as I have both handy I am unsure yet at the moment I am testing with the UNO.
I was hoping that by using PROGMEM I could still use the array but have it from the FLASH instead... I have looked at http://www.arduino.cc/en/Reference/PROGMEM and gotten the example working but I would like to do this for my mentioned array which I had this but its not working
PROGMEM const byte string_table[][8][64] = // change "string_table" name to suit
{0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,255,255,0,0,0,0,0,0,255,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,255,255,255,255,0,0,0,0,255,255,255,255,0,0,0,0,255,255,255,255,0,0,0,0,255,255,255,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0,0,255,255,255,255,255,255,0,0,255,255,255,255,255,255,0,0,255,255,255,255,255,255,0,0,255,255,255,255,255,255,0,0,255,255,255,255,255,255,0,0,255,255,255,255,255,255,0,0,0,0,0,0,0,0,0},
Can some one please give me some help on how to use PROGMEM for a very large 3D array? Thanks, Kriogenic.
