Hello,
I’m trying to play the Tetris theme on the Attiny 85 but then i realised that the SRAM was getting full half way thru the melody. So i decided to use PROGMEM. I added it and it complied with no errors, but when the melody plays it sounds strange. The melody seems to play all the way till the end but the tones seem to be wrong. Is the code for retrieve data wrong ?
Thank you in advance for any help.
PS. My code will play a melody when an IR single is detected and when the melody is done it will display a little light show.
#include "pitches.h"
#include "avr/pgmspace.h"
const int redPin = 1;
const int grnPin = 3;
const int bluPin = 4;
int inPin = 2;
// notes in the melody:
int melody[] PROGMEM = {
NOTE_DS5, NOTE_E5, NOTE_FS5, 0, NOTE_B5, NOTE_E5, NOTE_DS5, NOTE_E5, NOTE_FS5, NOTE_B5, NOTE_DS6, NOTE_E6, NOTE_DS6, NOTE_AS5, NOTE_B5, 0,
NOTE_FS5, 0, NOTE_DS5, NOTE_E5, NOTE_FS5, 0, NOTE_B5, NOTE_CS6, NOTE_AS5, NOTE_B5, NOTE_CS6, NOTE_E6, NOTE_DS6, NOTE_E6, NOTE_CS6,
NOTE_FS4, NOTE_GS4, NOTE_D4, NOTE_DS4, NOTE_FS2, NOTE_CS4, NOTE_D4, NOTE_CS4, NOTE_B3, NOTE_B3, NOTE_CS4,
NOTE_D4, NOTE_D4, NOTE_CS4, NOTE_B3, NOTE_CS4, NOTE_DS4, NOTE_FS4, NOTE_GS4, NOTE_DS4, NOTE_FS4, NOTE_CS4, NOTE_DS4, NOTE_B3, NOTE_CS4, NOTE_B3,
NOTE_DS4, NOTE_FS4, NOTE_GS4, NOTE_DS4, NOTE_FS4, NOTE_CS4, NOTE_DS4, NOTE_B3, NOTE_D4, NOTE_DS4, NOTE_D4, NOTE_CS4, NOTE_B3, NOTE_CS4,
NOTE_D4, NOTE_B3, NOTE_CS4, NOTE_DS4, NOTE_FS4, NOTE_CS4, NOTE_D4, NOTE_CS4, NOTE_B3, NOTE_CS4, NOTE_B3, NOTE_CS4,
NOTE_D4, NOTE_B3, NOTE_CS4, NOTE_DS4, NOTE_FS4, NOTE_CS4, NOTE_D4, NOTE_CS4, NOTE_B3, NOTE_CS4, NOTE_B3, NOTE_B3,
NOTE_B3, NOTE_FS3, NOTE_GS3, NOTE_B3, NOTE_FS3, NOTE_GS3, NOTE_B3, NOTE_CS4, NOTE_DS4, NOTE_B3, NOTE_E4, NOTE_DS4, NOTE_E4, NOTE_FS4,
NOTE_B3, NOTE_B3, NOTE_FS3, NOTE_GS3, NOTE_B3, NOTE_FS3, NOTE_E4, NOTE_DS4, NOTE_CS4, NOTE_B3, NOTE_E3, NOTE_DS3, NOTE_E3, NOTE_FS3,
NOTE_B3, NOTE_FS3, NOTE_GS3, NOTE_B3, NOTE_FS3, NOTE_GS3, NOTE_B3, NOTE_B3, NOTE_CS4, NOTE_DS4, NOTE_B3, NOTE_FS3, NOTE_GS3, NOTE_FS3,
NOTE_B3, NOTE_B3, NOTE_AS3, NOTE_B3, NOTE_FS3, NOTE_GS3, NOTE_B3, NOTE_E4, NOTE_DS4, NOTE_E4, NOTE_FS4, NOTE_B3, NOTE_AS3,
NOTE_B3, NOTE_B3, NOTE_AS3, NOTE_B3, NOTE_FS3, NOTE_GS3, NOTE_B3, NOTE_E4, NOTE_DS4, NOTE_E4, NOTE_FS4, NOTE_B3, NOTE_CS4,
NOTE_B3, NOTE_B3, NOTE_AS3, NOTE_B3, NOTE_FS3, NOTE_GS3, NOTE_B3, NOTE_E4, NOTE_DS4, NOTE_E4, NOTE_FS4, NOTE_B3, NOTE_CS4,};
// note durations: 4 = quarter note, 8 = eighth note, etc.:
int noteDurations[] PROGMEM = {
16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,
16,16,16,16,16,16,8,16,16,16,16,16,16,16,16,
8,8,16,16,16,16,16,16,8,8,8,
8,16,16,16,16,16,16,16,16,16,16,16,16,16,16,
8,8,16,16,16,16,16,16,16,16,16,16,16,16,
8,16,16,16,16,16,16,16,16,8,8,8,
8,16,16,8,16,16,16,16,16,16,16,16,16,16,
8,16,16,16,16,16,16,16,16,16,16,8,8,
8,16,16,16,16,16,16,16,16,16,16,8,8, };
// Setup for outputs
pinMode(redPin, OUTPUT);
pinMode(grnPin, OUTPUT);
pinMode(bluPin, OUTPUT);
pinMode(inPin, INPUT); // declare IR phototransistor as input
// Loop for fading
void loop () {
while(digitalRead(inPin) != LOW) {}; // read input value
// iterate over the notes of the melody:
int size = sizeof(melody) / sizeof(int);
for (int thisNote = 0; thisNote < size; thisNote++) {
// to calculate the note duration, take one second
// divided by the note type.
//e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
int noteDuration = 1000/ pgm_read_byte(&(noteDurations[thisNote]));
tone(0, pgm_read_byte(&(melody[thisNote])),noteDuration);
// to distinguish the notes, set a minimum time between them.
// the note's duration + 30% seems to work well:
int pauseBetweenNotes = noteDuration * 1.30;
delay(pauseBetweenNotes);
// stop the tone playing:
noTone(0);
