Hey everyone, long time no see.
For about a week now, I am trying to get PTP (picture transfer protocol) on M0 board (Trinket M0) working using USB host library (for SAMD). But no matter what, it just never works. Here is a function I use to setup the camera (endpoints and configs):
void camInit() {
//zero structs
for (int i = 0; i < 4; i++) {
ep_info[i].bmAttribs = 0;
ep_info[i].bmNakPower = 0;
ep_info[i].bmRcvToggle = 0;
ep_info[i].bmSndToggle = 0;
ep_info[i].epAddr = 0;
ep_info[i].epAttribs = 0;
ep_info[i].maxPktSize = 0;
//setup endpoints (retrieved from descriptors manually)
ep_info[0] = *(UsbH.getEpInfoEntry(0, 0));
ep_info[1].maxPktSize = 64;
ep_info[1].bmAttribs = 2;
ep_info[1].bmNakPower = 1;
ep_info[1].epAddr = 0x81;
ep_info[2].maxPktSize = 64;
ep_info[2].bmAttribs = 2;
ep_info[2].bmNakPower = 1;
ep_info[2].epAddr = 0x02; //0x82 but PTP
ep_info[3].maxPktSize = 64;
ep_info[3].bmAttribs = 3;
ep_info[3].bmNakPower = 1;
ep_info[3].epAddr = 0x83;
//set endpoints entry (camera has 4 nedpoints - control, in, out, interrupt)
int rcode;
rcode = UsbH.setEpInfoEntry(1, 4, ep_info);
u8x8log.printf("RC: %d\n", rcode);
//set config (my camera has only 1)
rcode = UsbH.setConf(1, 0, 1);
And here is a function that is supposed to send "GetDeviceInfo" command and retrieve at least some data:
void camPoll() {
int rcode;
uint16_t length = (sizeof(uint16_t)*2 + sizeof(uint32_t)*2); //dont care about the rest of the container
uint8_t data[length];
memset(data, 0, length);
//little endian
data[0] = 0x0C; //len 0
data[4] = 0x01; //type 0
data[6] = 0x01; //code 1
data[7] = 0x10; //code 0
//send command container
rcode = UsbH.outTransfer(1, 0x02, length, data);
//receive data
uint16_t read = 64;
uint8_t in_data[64];
memset(in_data, 0, 64);
rcode = UsbH.inTransfer(1, 0x81, &read, in_data);
//print data
for (int i = 0; i < 64; i++) {
u8x8log.printf("%02x", in_data[i]);
if ((i + 1) % 8 == 0) u8x8log.printf("\n");
- Device address is 1
- bulk out endpoint is 0x82, but PTP protocol requires out to be between 0x01 and 0x0f -> 0x02
- bulk in endpoint is 0x81
- max packet size is 64 (that's why read is 64)
The container I am sending is from here and is as follows:
size name
4B length - 12B as I don't have a payload
2B type - 0x0001 = command block
2B code - 0x1001 = GetDeviceInfo PTP command
4B transaction ID - 0x00000000 - GetDeviceInfo should have 0
?B payload - not used here
But no matter what, I always get return code 0 from both out and in transfers, yet no data from in (in_data is still zeroed). Also when sending the command for the third time, it then starts to return 2 instead of 0 (which is "USB_ERRORFLOW").
Do you guys have any idea what to do to make this work?
