using pullstime
// Should it be like this
#include <Servo.h>
Servo m1;
int unsigned long
const int buttonPin = A2;
const int ledPin = 9;
const int myPulseTime = writeMicroseconds(1500);
const int pulseIncrement = writeMicroseconds(250);
const int myPulseTime = (myPulseTime + pulseIncrement);
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;
/ initialize the button pin as a input:
  pinMode(buttonPin, INPUT);
  // initialize the LED as an output:
  pinMode(ledPin, OUTPUT);
  // initialize serial communication:
  buttonState = digitalRead(ButtonPin);
  if (buttonPushCounter % 1 == 0) {
  m1.attach(9);
    m1.write myPulseTime = (myPulseTime + pulseIncrement);
    delay(1);
    m1.writeMicroseconds(1000);
    delay(1);
    if (buttonPushCounter % 2 == 0) {
      m1.attach(9);
      delay(1);
      delay(1);
      if (buttonPushCounter % 3 == 0) {
        m1.attach(9);
        delay(1);
        delay(1);
No
buttonPin is presumably the number of a pin. It will not change in the program and it will not have a value of greater than 255 so a byte will be large enough to hold the value
So it should be
const byte buttonPin = A2;
and delete the previous line
did that thanks man, but I still get the "too many arguments to function 'long unsigned int millis()'" if i delete the thing.
You are trying to declare "myPulseTime" as two different constants. One of those will have to change names.
writeMicroseconds(1500) is not a constant. Use 1500 instead. writeMicroseconds(250) is not a constant. Use 250 instead.
Thanks so much, everything is working, but the damn thing is now saying: expected ‘;’ before ‘myPulsetime’
at the last segment ( the part before the special symbols).
#include <Servo.h>
Servo m1;
const int mypulseTime =  (1500);
const int pulseIncrement = (250);
const int myPulsetime = (mypulseTime + pulseIncrement);
  // initialize the button pin as a input:
  buttonState = digitalRead(buttonPin);
    m1.attach(9);
    m1.write myPulsetime = (myPulseTime + pulseIncrement);
    delay(1);
    delay(1);
      m1.attach(9);
      m1.write myPulsetime = (mypulseTime + pulseIncrement);
      delay(1);
      delay(1);
        m1.attach(9);
        delay(1);
        delay(1);
Matyk: Thanks so much, everything is working, but the damn thing is now saying: expected ';' before 'myPulsetime' at the last segment ( the part before the special symbols).
It can't be working if you are still getting errors while compiling
Post the code as it is now and the full error message
#include <Servo.h>
Servo m1;
const int mypulseTime = (1250);
m1.attach(9);
delay(1);
delay(1);
m1.attach(9);
delay(1);
delay(1);
m1.attach(9);
delay(1);
delay(1);
Arduino: 1.8.7 (Mac OS X), Board: “Arduino/Genuino Uno”
/Users/matyaskloc/Desktop/ESC-ARDUINO-CONTROL/ANother_one/ANother_one.ino: In function ‘void loop()’:
ANother_one:29:14: error: expected ‘;’ before ‘myPulsetime’
ANother_one:29:58: error: invalid use of non-static member function
ANother_one:39:16: error: expected ‘;’ before ‘myPulsetime’
ANother_one:39:60: error: invalid use of non-static member function
ANother_one:49:18: error: expected ‘;’ before ‘myPulsetime’
ANother_one:50:17: error: invalid use of non-static member function
delay(1);
exit status 1
What are you trying to write to the servo ?
Servos and ESCs get the same kind of signal, 50Hz signal. The pulse signal varies from 1ms to 2ms, with 1ms represents the motor off completely and 2ms is the maximum speed and anything between is also varying speed. so technically what I am trying to do is, for the first press of the button the signal would be 1500 (1250+250) so middle speed, second press it would be 1750 (1500+250) 3/4 of the max speed and for the third click, it would be 2000 (1750+250).
This should do what you want (or close to it) if you add the missing code to increment ‘buttonPushCounter’ when the button is pushed.
#include <Servo.h>
Servo m1;
const int PulseTimeBase = 1250;
const int PulseTimeIncrement = 250;
int myPulseTime = PulseTimeBase;
  m1.attach(9);
  switch (buttonPushCounter)
    case 1:  // First push: 1/2 speed
      myPulseTime = PulseTimeBase + PulseTimeIncrement;
    case 2: // Second push: 3/4 speed
      myPulseTime = PulseTimeBase + PulseTimeIncrement + PulseTimeIncrement;
    case 3: // Third push: Full speed
      myPulseTime = PulseTimeBase + PulseTimeIncrement + PulseTimeIncrement + PulseTimeIncrement;
    default:  // 1/4 speed and reset the push counter
  m1.writeMicroseconds(myPulseTime );
Matyk: Servos and ESCs get the same kind of signal, 50Hz signal. The pulse signal varies from 1ms to 2ms, with 1ms represents the motor off completely and 2ms is the maximum speed and anything between is also varying speed. so technically what I am trying to do is, for the first press of the button the signal would be 1500 (1250+250) so middle speed, second press it would be 1750 (1500+250) 3/4 of the max speed and for the third click, it would be 2000 (1750+250).
I am familiar with and understand all that and in your code you have instances of writing correctly to m1 like this
So why in other places in the code do you use the write() function like this ?
which is so obviously different
the m1.writeMicroseconds(1000); is for when nothing is pressed, so the motor speed would go to zero (1000), and the myPulsetime = (mypulseTime + pulseIncrement); is for the variation of speed (the thing is that can't have a potentiometer because this project is going underwater, so I just wanted 1 button that would vary through 3 speeds) I put the m1.write because I didn't know what function or whatever I should use.
I get that, but you are not writing myPulsetime to m1
You seem to know how to write 1000 to m1 so have a wild guess as to how you would write myPulsetime to it.
I appreciate your faith in me man, but I am quite sceptical I know what I am doing, would it be
m1.writemyPulsetime = (mypulseTime + pulseIncrement); ?
also, do you know what Johnwasser meant in the first comment of this page? the if you add the missing code to increment 'buttonPushCounter' when the button is pushed.
would it be
No
Take a deep breath and get your brain in gear.
If you want to write 1000 to m1 you use
This uses the Servo library function to write a value to the ESC. The value in this case is 1000.
You perform a calculation like this
after which myPulsetime has a value.
As an aside, how would you print that value ?
Rather than printing it you want to write the value of myPulsetime to m1. You know how to write 1000, so substitute myPulsetime for 1000 in the command and you will have written the value of myPulsetime to m1.
I do not want to simply give you the answer because it is important to think for yourself
I’d probably use the serial print, or is it a hit and miss?
Right, so I took my code which was edited by Johnwasser, which compiles however I can’t figure out if I should connect the button pin A2 to ground or to 5 volts
#include <Servo.h>
Servo m1;
const int PulseTimeBase = 1000;
int LastbuttonSate = 0;// current state of the button
  m1.attach(9);
    case 1:  // 1/4 speed and reset the push counter
     case 2:  // First push: 1/2 speed
    case 3: // Second push: 3/4 speed
    case 4: // Third push: Full speed
      myPulseTime = PulseTimeBase + PulseTimeIncrement + PulseTimeIncrement + PulseTimeIncrement + PulseTimeIncrement;
    default:  // reset  and reset the push counter
Matyk:
Yes, you would use Serial.print(). What would the command look like ?
I would either do
Serial.print(myPulsetime = (mypulseTime + pulseIncrement));
or Serial.print(1000)
However, I kind of got over that version so what do you think about this code? what should I connect the A2 to ground/ 5 volts? It wasn’t written by me I just edited it a bit.thanks for the help, man I really appreciate it
#include <Servo.h>
Servo m1;
  m1.attach(9);
