I am trying to read a timing gear to work out RPM. Right now I am just trying to see how I can determine when the sensor passes the larger gap in the gear but I can’t seem to get consistent results.
My code is:-
int pin = 6;
unsigned long Duration = 0;
pinMode(pin, INPUT_PULLUP);
Duration = pulseIn(pin, HIGH, 10000);
if (Duration != 0)
Serial.println(Duration);
Duration = 0;
A sample of the output is :-
16:34:49.176 -> 904
16:34:49.176 -> 1011
16:34:49.223 -> 946
16:34:49.223 -> 840
16:34:49.223 -> 789
16:34:49.223 -> 704
16:34:49.223 -> 752
16:34:49.223 -> 791
16:34:49.223 -> 797
16:34:49.223 -> 749
16:34:49.223 -> 708
16:34:49.270 -> 727
16:34:49.270 -> 775
16:34:49.270 -> 1332
16:34:49.270 -> 626
16:34:49.270 -> 795
16:34:49.270 -> 809
16:34:49.270 -> 776
16:34:49.270 -> 750
16:34:49.270 -> 752
16:34:49.317 -> 754
16:34:49.317 -> 723
16:34:49.317 -> 666
16:34:49.317 -> 656
16:34:49.317 -> 707
16:34:49.317 -> 767
16:34:49.317 -> 712
16:34:49.317 -> 708
16:34:49.317 -> 839
16:34:49.364 -> 814
16:34:49.364 -> 757
16:34:49.364 -> 651
16:34:49.364 -> 754
16:34:49.364 -> 1394
16:34:49.364 -> 756
16:34:49.364 -> 710
16:34:49.364 -> 677
16:34:49.411 -> 760
16:34:49.411 -> 743
16:34:49.411 -> 807
16:34:49.411 -> 781
16:34:49.411 -> 731
16:34:49.411 -> 772
16:34:49.411 -> 804
16:34:49.411 -> 884
16:34:49.411 -> 841
16:34:49.411 -> 1390
16:34:49.458 -> 783
16:34:49.458 -> 850
16:34:49.458 -> 840
16:34:49.458 -> 810
16:34:49.458 -> 861
16:34:49.458 -> 855
16:34:49.458 -> 829
16:34:49.458 -> 826
16:34:49.504 -> 830
16:34:49.504 -> 852
16:34:49.504 -> 872
16:34:49.504 -> 870
16:34:49.504 -> 871
16:34:49.504 -> 1466
16:34:49.504 -> 802
16:34:49.504 -> 857
16:34:49.504 -> 849
16:34:49.504 -> 867
16:34:49.551 -> 876
16:34:49.551 -> 869
16:34:49.551 -> 850
16:34:49.551 -> 854
16:34:49.551 -> 869
16:34:49.551 -> 872
16:34:49.551 -> 881
16:34:49.551 -> 905
16:34:49.598 -> 907
16:34:49.598 -> 889
16:34:49.598 -> 1485
16:34:49.598 -> 841
16:34:49.598 -> 898
16:34:49.598 -> 898
16:34:49.598 -> 904
16:34:49.598 -> 901
16:34:49.598 -> 894
16:34:49.645 -> 885
16:34:49.645 -> 895
16:34:49.645 -> 894
16:34:49.645 -> 907
16:34:49.645 -> 929
16:34:49.645 -> 940
16:34:49.645 -> 945
16:34:49.645 -> 935
16:34:49.645 -> 930
16:34:49.692 -> 941
16:34:49.692 -> 941
16:34:49.692 -> 949
16:34:49.692 -> 946
16:34:49.692 -> 947
16:34:49.692 -> 938
16:34:49.692 -> 927
16:34:49.692 -> 916
16:34:49.692 -> 930
16:34:49.739 -> 926
16:34:49.739 -> 941
16:34:49.739 -> 953
16:34:49.739 -> 968
16:34:49.739 -> 966
16:34:49.739 -> 972
16:34:49.739 -> 967
16:34:49.739 -> 1541
16:34:49.739 -> 918
16:34:49.786 -> 971
16:34:49.786 -> 976
16:34:49.786 -> 984
16:34:49.786 -> 980
16:34:49.786 -> 949
16:34:49.786 -> 961
16:34:49.786 -> 951
16:34:49.786 -> 930
16:34:49.786 -> 934
16:34:49.833 -> 963
16:34:49.833 -> 963
16:34:49.833 -> 981
16:34:49.833 -> 1012
16:34:49.833 -> 987
16:34:49.833 -> 1585
16:34:49.833 -> 950
16:34:49.879 -> 985
16:34:49.879 -> 1004
16:34:49.879 -> 1033
16:34:49.879 -> 1051
16:34:49.879 -> 1008
16:34:49.879 -> 970
16:34:49.879 -> 973
16:34:49.879 -> 985
16:34:49.926 -> 987
16:34:49.926 -> 959
16:34:49.926 -> 977
16:34:49.926 -> 1027
16:34:49.926 -> 1030
16:34:49.926 -> 1034
16:34:49.926 -> 1018
16:34:49.926 -> 1045
16:34:49.973 -> 1042
16:34:49.973 -> 1056
16:34:49.973 -> 1020
16:34:49.973 -> 1017
16:34:49.973 -> 1007
16:34:49.973 -> 1004
16:34:50.020 -> 1009
16:34:50.020 -> 958
16:34:50.020 -> 966
16:34:50.020 -> 1027
16:34:50.020 -> 1075
16:34:50.020 -> 1089
16:34:50.020 -> 1060
16:34:50.067 -> 1054
16:34:50.067 -> 1614
16:34:50.067 -> 1048
16:34:50.067 -> 1090
16:34:50.067 -> 1097
16:34:50.067 -> 1107
16:34:50.067 -> 1112
16:34:50.067 -> 1096
16:34:50.114 -> 1066
16:34:50.114 -> 1035
16:34:50.114 -> 1007
16:34:50.114 -> 986
16:34:50.114 -> 978
16:34:50.114 -> 977
16:34:50.114 -> 984
16:34:50.114 -> 995
16:34:50.161 -> 1035
16:34:50.161 -> 1078
16:34:50.161 -> 1076
16:34:50.161 -> 1082
16:34:50.161 -> 1055
16:34:50.161 -> 1095
16:34:50.161 -> 1112
16:34:50.161 -> 1106
16:34:50.208 -> 1105
16:34:50.208 -> 1102
16:34:50.208 -> 1078
16:34:50.208 -> 1068
16:34:50.208 -> 1038
16:34:50.208 -> 991
16:34:50.208 -> 971
16:34:50.208 -> 964
16:34:50.254 -> 963
16:34:50.254 -> 984
16:34:50.254 -> 986
16:34:50.254 -> 996
16:34:50.254 -> 1031
16:34:50.254 -> 1068
16:34:50.254 -> 1073
16:34:50.254 -> 1069
16:34:50.254 -> 1066
16:34:50.301 -> 1036
16:34:50.301 -> 1643
16:34:50.301 -> 1086
16:34:50.301 -> 1076
16:34:50.301 -> 1077
16:34:50.301 -> 1108
16:34:50.301 -> 1125
16:34:50.348 -> 1047
16:34:50.348 -> 1009
16:34:50.348 -> 966
16:34:50.348 -> 890
16:34:50.348 -> 866
16:34:50.348 -> 854
16:34:50.348 -> 853
16:34:50.348 -> 839
16:34:50.395 -> 865
16:34:50.395 -> 848
16:34:50.395 -> 872
16:34:50.395 -> 908
16:34:50.395 -> 948
16:34:50.395 -> 959
16:34:50.395 -> 940
16:34:50.395 -> 842
16:34:50.395 -> 1571
16:34:50.442 -> 804
16:34:50.442 -> 852
16:34:50.442 -> 915
16:34:50.442 -> 870
16:34:50.442 -> 670
Now there are 22 gaps on the wheel and one gap is 3x larger than the others. I can see that the duration to the next high is periodically a lot larger than the other gap readings but they do not always come at 22 reading intervals.
I have a pulse read of 0.01 second as the timing gear wheel will be spinning at various speeds.
Please see the attached for a picture of the timing wheel.
Thanks, Daniel.
