Using Pushbutton to switch between LCD screens
Hi all,
I am working on a project with an ESP8266 that reads sensors and publishes to a HTML webpage. I also want to be able to read the data on a 16 x 2 I2C LCD. All of that stuff is set up, but I am having problems reading a pushbutton to switch between readings. I.e., Push button to display air temp, push again, display humidity, etc.
Here is the code that I have currently:
#include <ESP8266WiFi.h>
#include <Wire.h>
#include <Adafruit_BMP085.h>
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <OneWire.h>
#include <DallasTemperature.h>
//Static IP setup
IPAddress staticIP (10, 0, 0, 50);
IPAddress gateway (10, 0, 0, 1);
IPAddress subnet (255, 255, 255, 0);
//wifi information
const char* ssid = "SSID";
const char* password = "PASSWORD";
//server
WiFiServer server(80);
//integers
int ledPin = 16;
int buttonState = 0;
int previousButtonState = 0;
const int menuButton = 10;
const int adcPin = A0;
static int presses = 0;
//definitions
#define DHTTYPE DHT11
#define DHTPIN 0
#define ONE_WIRE_BUS 2
Adafruit_BMP085 bmp;
DHT dht(DHTPIN, DHTTYPE);
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
LiquidCrystal_I2C lcd = LiquidCrystal_I2C (0x27, 16, 2);
//floats
float WaterC = 0;
float WaterF = 0;
const float m = -5.59701;
//Millis Timing
unsigned long previousMillis = 0;
const long interval = 500;
  pinMode(ledPin, OUTPUT);
  pinMode(menuButton, INPUT);
  WiFi.hostname("Greenhouse Monitor");
  WiFi.begin(ssid, password);
  WiFi.disconnect();
  WiFi.hostname ("Greenhouse Monitor");
  WiFi.config(staticIP, subnet, gateway);
  dht.begin();
  lcd.init();
  lcd.backlight();
  if (!bmp.begin()){
    Serial.println("Check wiring...");
    while(1);
  server.begin();
//Barometric Pressure
  float PressurePa = bmp.readPressure();
  float PressureInHg = (PressurePa + 3966)/3386 ;
//Temperature
  float TempC = bmp.readTemperature();
  float TempF = (TempC *9/5) + 32;
//humidity
  float humidity = dht.readHumidity();
//Dew Point
  float dewPointF = TempF - ((100 - humidity) * 0.36);
  float dewPointC = (dewPointF - 32) * 5/9;
//Water Temperature
  sensors.requestTemperatures();
  WaterC = sensors.getTempCByIndex(0);
  WaterF = sensors.toFahrenheit(WaterC);
//pH Sensor
  float Po = analogRead(adcPin) * 3.3 / 1024;
  float phValue = 7 - (1.65 - Po) * m;
//Menu Button
  if (currentMillis - previousMillis >= interval){
       buttonState = digitalRead(menuButton);
        if (buttonState == HIGH){
          presses = presses + 1;
          delay(10);
//LCD Menus
  if (presses == 0){
    lcd.setCursor(0, 0);
    lcd.print("Air Temp");
    lcd.setCursor(0, 1);
    lcd.print(TempF);
  }else
    if (presses == 1){
    lcd.print("Humidity");
    lcd.print(humidity);
  }else
    if (presses == 2){
    lcd.print("Dew Point");
    lcd.print(dewPointF);
  }else
    if (presses == 3){
    lcd.print("Pressure");
    lcd.print(PressureInHg);
  }else
    if (presses == 4){
    lcd.print("Water Temp");
    lcd.print(WaterF);
  }else
    if (presses == 5){
    lcd.print("pH Level");
    lcd.print(phValue);
  }else
    if (presses == 6){
    lcd.print("Pump 1");
  }else
    if (presses == 7){
    lcd.print("Pump 2");
  }else
    if (presses >= 8){
    presses = 0;
  }else{}
   WiFiClient client = server.available();
   String request = client.readStringUntil('\r');
      if (client){
          client.println("HTTP/1.1 200 OK"); //send new page
          client.println("Content-Type: text/html");
          client.println();
          client.println("<HTML>");
          client.println("<HEAD>");
          client.println("<TITLE> Greenhouse Monitor</TITLE>");
          client.println("</HEAD>");
          client.println("<BODY bgcolor=#000000>");
          client.println("<H1 style=\"color:Green;\">Shenango Greenhouse Monitor</H1>");
          client.println("<hr>");
          client.println("
          client.println("<H1 style=\"color:Green;\">Grow Lights:</H1>");
          client.println("<H3><a href=\"/?GROWON\"\">Turn On Growlights</a>
</H2>");
          client.println("<H3><a href=\"/?GROWOFF\"\">Turn Off Growlights</a>
</H2>");
          client.println("<H1 style=\"color:Green;\">Air Temperature:</H1>");
          client.println("<H3 style=\"color:White;\">");
          client.println(TempC);
          client.println("C");
          client.println("
          client.println(TempF);
          client.println("F");
          client.println("</H3>");
          client.println("<H1 style=\"color:Green;\">Relative Humidity:</H1>");
          client.println(humidity);
          client.println("%");
          client.println("<H1 style=\"color:Green;\">Dew Point</H1>");
          client.println(dewPointC);
          client.println(" C");
          client.println("
          client.println(dewPointF);
          client.println(" F");
          client.println("<H1 style=\"color:Green;\">Barometric Pressure:</H1>");
          client.println(PressurePa);
          client.println(" Pa");
          client.println("
          client.println(PressureInHg);
          client.println(" InHg");
          client.println("<H1 style=\"color:Green;\">Water Temperature:</H1>");
          client.println(WaterC);
          client.println("
          client.println(WaterF);
          client.println("<H1 style=\"color:Green;\">Water Acidity:</H1>");
          client.println(phValue);
          client.println(" pH");
          client.println("<H1 style=\"color:Green;\">Flow Valve 1:</H1>");
          client.println(" L/Min");
          client.println("<H1 style=\"color:Green;\">Flow Valve 2:</H1>");
          client.println("
          client.println("</BODY>");
          client.println("</HTML>");
            if (request.indexOf("/?GROWON") != -1){
              digitalWrite(ledPin, LOW);
            if (request.indexOf("/?GROWOFF") != -1){
              digitalWrite(ledPin, HIGH);
          delay(10);
          client.stop();
This works, but I have to hold down the button for about 5 seconds before it goes to the next reading. I feel as though I don't have the millis set up correctly in the loop:
//Menu Button
          delay(10);
Does anyone have any idea of what I did wrong here?
try
byte interval = 50; // (range 0-255)
Use the autoformat function. That makes it more clear to see things. Your code is rather free from delays but why update LCD and/or the client almost 100 times per second? That will fill buffers and make calls be hanging is my idea.
wolframore:
try
I just tried that and the same result occurred :frowning:
Railroader:
#include <Wire.h>
#include <DHT.h>
//Static IP setup
//wifi information
const char* ssid = "nomoregaming 2.4GHz";
const char* password = "tonyjoey2011?";
//server
//integers
int ledPin = 16;
//definitions
#define DHTPIN 0
//floats
float WaterC = 0;
float WaterF = 0;
//Millis Timing
byte interval = 500;
  WiFi.disconnect();
  dht.begin();
  lcd.init();
  lcd.backlight();
  if (!bmp.begin()) {
    while (1);
  server.begin();
  float PressureInHg = (PressurePa + 3966) / 3386 ;
  //Temperature
  float TempF = (TempC * 9 / 5) + 32;
  //humidity
  //Dew Point
  float dewPointC = (dewPointF - 32) * 5 / 9;
  //Water Temperature
  //pH Sensor
  //Menu Button
  if (currentMillis - previousMillis >= interval) {
    if (buttonState == HIGH) {
      delay(10);
  //LCD Menus
  if (presses == 0) {
    lcd.print(TempF);
  } else if (presses == 1) {
  } else if (presses == 2) {
  } else if (presses == 3) {
  } else if (presses == 4) {
    lcd.print(WaterF);
  } else if (presses == 5) {
    lcd.print(phValue);
  } else if (presses == 6) {
  } else if (presses == 7) {
  } else if (presses >= 8) {
    presses = 0;
  } else {}
  if (client) {
    client.println();
    client.println("
</H2>");
</H2>");
    client.println("
    client.println("
    client.println("
    client.println("
    client.println("
  if (request.indexOf("/?GROWON") != -1) {
  if (request.indexOf("/?GROWOFF") != -1) {
  delay(10);
  client.stop();
Sorry, here is my code auto-formatted. What would be the best way to slow down the loop a bit in you r opinion?
Don't update "everything" every turn of loop. Then buffers etc. will not be overloaded.
Railroader:
So could I create a, say Void Air Temperature () with the stuff to read the temperature sensor and then in the loop just use millis to call that Void Air Temperature every 5 seconds in the loop or is there an easier way to do it?
Yes. And maybe call the client business in the same way, a little bit less often.
Railroader:
Ok thank you. I will do that! Much appreciated!
.readStringUntil() will be blocking to a default (1 sec?) timeout value each pass through loop if there is no '\r' to read.
cattledog:
So I need to change the default value then? Or just omit it completely?
What sends the "request" and how often. Is the request always terminated with'\r'?
I think you want to only read if client.available() and the section could be blocked like this
if(client.available() > 0)
