Good day. I've been learning on how to transfer data from Arduino to Raspberry Pi wirelessly using NRF24L01 based on the following reference:
Raspberry Pi 3 Tutorial 14 – Wireless Pi to Arduino Communication with NRF24L01+
The reason why I want to do this is to log temperature and humidity data wirelessly using DHT22 sensors.
The Arduino code is shown below:
//SendReceive.ino
#include<SPI.h>
#include<RF24.h>
// CE, CSN pins
RF24 radio(9, 10);
void setup(void){
while(!Serial);
radio.begin();
radio.setPALevel(RF24_PA_MAX);
radio.setChannel(0x76);
radio.openWritingPipe(0xF0F0F0F0E1LL);
const uint64_t pipe = (0xE8E8F0F0E1LL);
radio.openReadingPipe(1, pipe);
radio.enableDynamicPayloads();
radio.powerUp();
void loop(void){
radio.startListening();
Serial.println("Starting loop. Radio on.");
char receivedMessage[32] = {0};
if(radio.available()){
radio.read(receivedMessage, sizeof(receivedMessage));
Serial.println(receivedMessage);
Serial.println("Turning off the radio.");
radio.stopListening();
String stringMessage(receivedMessage);
if(stringMessage == "GETSTRING"){
Serial.println("Looks like they want a string!");
const char text[] = "Yo wassup, haha";
radio.write(text, sizeof(text));
Serial.println("We sent our message.");
delay(100);
Meanwhile, the Raspberry Pi code is shown below:
import RPi.GPIO as GPIO
from lib_nrf24 import NRF24
import time
import spidev
GPIO.setmode(GPIO.BCM)
pipes = [[0xE8, 0xE8, 0xF0, 0xF0, 0xE1], [0xF0, 0xF0, 0xF0, 0xF0, 0xE1]]
radio = NRF24(GPIO, spidev.SpiDev())
radio.begin(0, 17)
radio.setPayloadSize(32)
radio.setDataRate(NRF24.BR_1MBPS)
radio.setPALevel(NRF24.PA_MIN)
radio.setAutoAck(True)
radio.enableAckPayload()
radio.openWritingPipe(pipes[0])
radio.openReadingPipe(1, pipes[1])
radio.printDetails()
# radio.startListening()
message = list("GETSTRING")
while len(message) < 32:
message.append(0)
while(1):
start = time.time()
radio.write(message)
print("Sent the message: {}".format(message))
while not radio.available(0):
time.sleep(1 / 100)
if time.time() - start > 2:
print("Timed out.")
break
receivedMessage = []
radio.read(receivedMessage, radio.getDynamicPayloadSize())
print("Received: {}".format(receivedMessage))
print("Translating the receivedMessage into unicode characters")
string = ""
for n in receivedMessage:
# Decode into standard unicode set
if (n >= 32 and n <= 126):
string += chr(n)
print("Out received message decodes to: {}".format(string))
time.sleep(1)
Based on the Arduino code above, the code that shows the data that is transmitted is shown below:
Based on the Raspberry code above, the codes that decode the received data from Arduino are shown below:
string += chr(n)
However, these decoding code only works if I transmit string or integer from Arduino to Raspberry Pi. It doesn't work if I transmit float. Since DHT22 records temperature and humidity up until 1 decimal point, it is required for me to transmit float. Can anyone here please teach me how to decode the float values?
Thank you very much.
