using RepRapDiscount Full Graphic Smart Controller encoder.
Hello guys,
I have bought this module: RepRapDiscount Full Graphic Smart Controller - RepRap
and I want to use it for other purpose instand of 3D printers.
I've managed to access to the beeper and the 128*64 LCD and the rotary button,
But I was unable to detect right\left movement on the rotary, I have attached Rotary encoder to arduino before this way.
Using the code that i've wrote:
#include <Wire.h>
#define inputROTARYBUTTON 12
#define inputRIGHT 10
#define inputLEFT 11
#define BUTTONCLICKED 0
 int counter = 0;
 int currentState;
 int previousState;
bool ButtonClicked(int id){
  return (digitalRead(id) == BUTTONCLICKED);
  Serial.begin (9600);
   // Set encoder pins as inputs
   pinMode (inputRIGHT,INPUT);
   pinMode (inputLEFT,INPUT);
   pinMode(inputROTARYBUTTON, INPUT_PULLUP);
   digitalWrite(inputROTARYBUTTON, HIGH);
   // Setup Serial Monitor
   previousState = digitalRead(inputRIGHT);
  delay(10);
   currentState = digitalRead(inputRIGHT);
   if (currentState != previousState){
     if (digitalRead(inputLEFT) != currentState) {  //TURN RIGHT
       counter --;
     } else { //TURN LEFT
       counter ++;
     Serial.print("Value: ");
     Serial.println(counter);
   previousState = currentState;
   if(ButtonClicked(inputROTARYBUTTON) == 1){
     Serial.println("clicked!");
according to "RepRap ..... smart controller" schematic I've plugged 3,5PINS on EXP2 to pin 10,11 on Arduino, but its seem to be all the time as 'HIGH'.
how cam i fix it?
set the pinModes to INPUT_PULLUP. With gnd to Arduino ground, of course. The encoder outputs are switches, so treat them as such.
