Using reset pin and millis() how i reset Mega board every 1 hour interval
I have to reset my Arduino mega board every 1 hour. Can anyone help?
why?
Juraj:
why?
I bet everyone wanted to ask that but you beat everyone to it :wink:
Juraj:
why?
When I checking continuously sensor data device give wrong value and if restart it starts working fine.
So, I want to restart the device.
bytebd:
solve the problem
Juraj:
solve the problem
Or to put it another way :wink: if you want help solving the problem post the code and schematic, and link to the sensor datasheet.
Resetting the device is so I.T. Crowd...
Juraj:
solve the problem
No, Now I am now doing this by manually, so I want to do it by automatically
and you don't know how to code the timing or the reset?
bytebd:
Yeah we get that, but you still haven't said why you don't fix the underlying problem in the first place.
:slight_smile: Maybe you could rig a small servo to press the reset button?
bytebd:
With properly written code there should be no need to reset the Arduino.
If you really need a back-up in case of a failure of the program then that is what the Watchdog Timer is for.
...R
I am using something like this with Watchdog
#include <avr/wdt.h>
  wdt_disable();
  Serial.begin(19200);
  Serial.println("Setup! Check the LED.");
  pinMode(13, OUTPUT);
  delay(5000);
  wdt_enable(WDTO_2S);
  Serial.println("Main Loop!");
  for (int cnt = 0; cnt < 5; cnt++) {
    Serial.println(cnt);
    digitalWrite(13, LOW);
    digitalWrite(13, HIGH);
    wdt_reset();
  Serial.println("Reset by Watch Dog?");
  delay(3000);
  // Code should never get to here
  Serial.println("Reset failed");
bytebd:
Did it solve the problem?
Micros() rollover, 71.5827882667 minutes? Need to see code.
outsider:
I was thinking millis() and wondered how it could be the culprit; but I always forget about micros()- you're probably right.
bytebd:
The difference between your code and "something like it" could be fatal. Post the actual program that is causing the problem.
...R
