Using "return' for the first time, trouble with the output
I was shy about making booleans as functions, but finally I saw how convenient it is…
So I wrote
bool Compl_Legs (float Tolerance)
if ((Gap_M[1] < Tolerance) && (Gap_M[2] < Tolerance) && (Gap_M[3] < Tolerance) && Gap_M[11] < Tolerance && (Gap_M[12] < Tolerance) && (Gap_M[13] < Tolerance) )
return 1;
else // Attention: Printing these errors will slow the processor and cause the Switch case function to skip steps.
return 0;
(I am monitoring the gaps in a robot motor legs, the entire sketch is humongous . )
Serial.print ("Compl_Legs: ");
Serial.println (Compl_Legs);
Then I get
no matching function for call to ‘println(bool (&)(float))’
Why can’t print out? It is still a bool?
Thanks for help
Serial.println ( Compl_Legs() );
Also you should return 'true' and 'false', not '1' and '0'. It shows the reader and the compiler both, what type it really is.
And you will need to pass a ‘float’ value for ‘Tolerance’.
And, since the expression being ‘true’ returns ‘true’ and ‘false’ returns ‘false’, you can return the expression itself:
    return 1;
    return 0;
becomes:
 return (Gap_M[1] < Tolerance) && (Gap_M[2] < Tolerance) && (Gap_M[3] < Tolerance) &&
      Gap_M[11] < Tolerance && (Gap_M[12] < Tolerance) && (Gap_M[13] < Tolerance);
that worked, thanks a lot
