Using RF Transmitter Without Second Arduino
Actually, i want work with one Arduino, and my Mac. Is it possible? I don't want another Arduino, i prefer to use this things receiver version and Microcontroller only.
The Arduino can run either the receiver or the transmitter. Take your pick.
The Mac can't run either the receiver or the transmitter.
Okay, can i use microcontrollers only?
Yes, you need something that can produce a data format with no DC component, which requires a data port where you can directly control the state. You could use a raspberry pi as it has raw data ports which you can directly control. If you want to use the MAC, you could look at differant radios which have a serial port.
