Using RFGarage Gate Door Remote and a receiver for Arduino
Hi guys,
I want to use 20 cheap RF (U$5 max) to control a Arduino. BUT, I need that this cheap RF control send ID (0-19) and button pressed 1,2,3
Like, 043: id = 04/button = 3 181: id = 18/button = 1
I need a control, doesn't work for me buy a chip and start from the bottom. And I need a receiver for arduino
I found a remote control for U$4 that uses HT6P20B (Code Learning), now I need a receiver for Arduino.
Working code!
Receiving ID from Code Learning control!
Dene from here did it!
 ARDUINO DECODIFICADOR HT6P20B COM RESISTOR DE 2M2 NO OSC.
 ESTE CÓDIGO NÃO USA TIMER, INTERRUPÇÃO EXTERNA E NEM PINO DEFINIDO DE ENTRADA.
 ELE MEDE O TEMPO DO PILOT PERIOD E COMPARA SE ESTÁ DENTRO DA FAIXA DEFINIDA,
 SE TIVER ELE PASSA PARA CODE PERIOD E FAZ AS MEDIDÇÕES DE TEMPO EM NIVEL ALTO
 SE TIVER DENTRO DA FAIXA ACRECENTA BIT 1 OU 0 NA VARIAVEL _DATA CASO NÃO ZERA AS VARIÁVEIS E RE-INICIA
 APOS RECEBER TODOS OS BITS ELE PEGA OS 4 BITS DO ANTE CODE E TESTA PARA SABER SE O CÓDIGO FOI RECEBIDO
 CORRETAMENTE, CASO RECEBIDO CERTO ELE COLOCA A VARIAVEL ANTCODE EM 1.
 CRIADO POR: JACQUES DANIEL MORESCO
 DATA: 28/02/2012 USANDO ARDUINO 0022.
 FONES:54 3324 2251 54 9206 7168
 E-MAIL: ibisul@ibisul.com.br
 Permitido o uso público, mas deve-se manter o nome do autor.
int x,startbit,ctr,dataok,t1,larpulso,larpulso1,larpulso2,larpulso3,larpulso4,bt1,bt2,antcode=0;
unsigned long _data=0;   // DATA é o Código recebio do HT6p20 todos os 28 BITS onde, 22 do coodigo+2 dos botões+4 do anti-codigo;
unsigned long _dur,_dur1;      // Duração do Pulso
byte          _pin;    // Pino que vai receber o sinal RF digital.
void setup(){
  _pin=2;
  pinMode(2, INPUT);
  //pinMode(13, OUTPUT);
  pinMode(13,OUTPUT); // D13 - 1 RF +VCC
  pinMode(12,OUTPUT); // D12 - 2 RF GND
  pinMode(7,OUTPUT); // D7 - 7 RF GND
  pinMode(5,OUTPUT); // D5 - 10 AF +VCC
  pinMode(4,OUTPUT); // D4 - 11 AF GND
  digitalWrite(13,1); // D13 - 1 RF +VCC
  digitalWrite(12,0); // D12 - 2 RF GND
  digitalWrite(7,0); // D7 - 7 RF GND
  digitalWrite(5,1); // D5 - 10 AF +VCC
  digitalWrite(4,0); // D4 - 11 AF GND
void loop(){
  //digitalWrite(13, digitalRead(2)); //Pisca o LED conforme o valor da entrada digital, testar interferencias.
  if (startbit==0)
  {// Testa o tempo piloto até o Bit de inicio;
    _dur = pulseIn(_pin, LOW);
    if(_dur > 8000 && _dur < 12000 && startbit==0)
      larpulso=_dur/23;
      larpulso1=larpulso-50;
      larpulso2=larpulso+50;
      larpulso3=larpulso+larpulso-50;
      larpulso4=larpulso+larpulso+50;
      startbit=1;
      _dur=0;
      _data=0;
      dataok=0;
      ctr=0;
  // Se o Bit de inicio OK ENTÃO Inicia a medição do tempo em Nivel ALTO dos sinais, e testa se o tempo está na faixa.
  if (startbit==1 && dataok==0 && ctr < 28)
    ++ctr;
    _dur1 = pulseIn(_pin, HIGH);
    if(_dur1 > larpulso1 && _dur1 < larpulso2)     // Se a largura de pulso é entre 1/4000 e 1/3000 segundos
      _data = (_data << 1) + 1;      // anexar um * 1 * para a extremidade mais à direita do buffer
    else if(_dur1 > larpulso3 && _dur1 < larpulso4)   // Se a largura de pulso é entre 2/4000 e 2/3000 segundos
      _data = (_data << 1);       // anexar um * 0 * para a extremidade mais à direita do buffer
      /* força finalização do laço */
      startbit=0;
  if (ctr==28)
    if (bitRead(_data,0)==1)
      if (bitRead(_data,1)==0)
        if (bitRead(_data,2)==1)
          if (bitRead(_data,3)==0)
            antcode=1;
    if (antcode==1)
    {// Se foram recebidos todos os 28 Bits, o valor vai para a variavel _data e pode ser usada como exemplo abaixo.
      dataok=1;
      Serial.print("ID: ");
      Serial.println(_data/16,BIN);
      ctr=0;
      startbit=0;
      antcode=0;
      delay(100);
Hi Guys!
I developed a sketch based on the nice code above and many others.. For all "remote controls" that use the encoder HT6P20 I tested, it worked!
See the links below: English: http://acturcato.wordpress.com/2014/01/04/decoder-for-ht6p20b-encoder-on-arduino-board-english/
Portuguese: http://acturcato.wordpress.com/2013/12/20/decodificador-para-o-encoder-ht6p20b-em-arduino/
