using RFM02 to connect two arduinos
Hi
i wanted to build a simple setup with 2 arduinos one as transmitter and one as reciver
the transmitter should have 2 buttons if i press button 1 he should send some code via rf (1) to the other arduino and if i press button 2 he shoul send another code (2).
so that te reciver arduino lights up led1 oder led2
i already found a library whit that i could do this
http://ninjablocks.com/blogs/how-to/7501042-adding-rf-433mhz-to-your-arduino
my problem is that by mistake i orderd the RFM02 transmitter instead of a simple one like these
on the reciving end i have a RFM12 or these http://www.conrad.de/ce/de/product/130428/Funk-Sender-Empfaenger-Set-433-MHz-AM-Baustein-Sender-3-12-VACDC-Empfaenger-5-VACDC-Reichweite-max-30-m.
is there a way to make this work with the RFM02 ?
i am realy not good at programming so i would need sample code that i just have to change.
with the simple one i would have done it without problem.
Thanks in advance
sorry for my bad english
yes it is possible please this post
http://www.contrechoc.com/fablab/RF01-02.zip
