Using RFM69HCW module with Arduino Nano 33 IoT for LoRa
Hi everyone,
I am a newbie working with the Nano 33 IoT (SAMD21-M0 processor) and the radio module (Adafruit RFM69HCW) and am currently facing issues transmitting packets from a node device to a gateway device:
  1. The serial print statements in void setup() does not get printed
  2. The node seems to be sending messages but the gateway does not receive them.
I have made sure that the com ports are set up correctly in the IDE. I am using 2 separate IDEs for each code respectively.
Here is the pinout that I use to set up the hardware
Arduino 3.3V -> VIN
Ardurino GND -> GND
Arduino SCK (D13) -> SCLK
Arduino MISO (D12) -> MISO
Arduino MOSI (D11) -> MOSI
Arduino (D4) -> CS
Arduino (D5) -> RST
Arduino (D10) -> G0 (this is hardware interrupt)
Below are my testing node code and gateway code
/* Node side*/
// RFM69HCW Example Sketch
// Send serial input characters from one RFM69 node to another
// Based on RFM69 library sample code by Felix Rusu
// http://LowPowerLab.com/contact
// Modified for RFM69HCW by Mike Grusin, 4/16
// This sketch will show you the basics of using an
// RFM69HCW radio module. SparkFun's part numbers are:
// 915MHz: https://www.sparkfun.com/products/12775
// 434MHz: https://www.sparkfun.com/products/12823
// See the hook-up guide for wiring instructions:
// https://learn.sparkfun.com/tutorials/rfm69hcw-hookup-guide
// Uses the RFM69 library by Felix Rusu, LowPowerLab.com
// Original library: https://www.github.com/lowpowerlab/rfm69
// SparkFun repository: https://github.com/sparkfun/RFM69HCW_Breakout
// Include the RFM69 and SPI libraries:
#include <RFM69.h>
#include <SPI.h>
// Addresses for this node. CHANGE THESE FOR EACH NODE!
#define NETWORKID     0   // Must be the same for all nodes
#define MYNODEID      1   // My node ID
#define TONODEID      2   // Destination node ID
// RFM69 frequency, uncomment the frequency of your module:
#define FREQUENCY   RF69_433MHZ
//#define FREQUENCY     RF69_915MHZ
// AES encryption (or not):
#define ENCRYPT       true // Set to "true" to use encryption
#define ENCRYPTKEY    "TOPSECRETPASSWRD" // Use the same 16-byte key on all nodes
// Use ACKnowledge when sending messages (or not):
#define USEACK        true // Request ACKs or not
// Packet sent/received indicator LED (optional):
#define LED           9 // LED positive pin
#define GND           8 // LED ground pin
// Create a library object for our RFM69HCW module:
RFM69 radio;
  // Open a serial port so we can send keystrokes to the module:
  Serial.print("Node ");
  Serial.print(MYNODEID,DEC);
  Serial.println(" ready");
  // Set up the indicator LED (optional):
  pinMode(LED,OUTPUT);
  digitalWrite(LED,LOW);
  pinMode(GND,OUTPUT);
  digitalWrite(GND,LOW);
  // Initialize the RFM69HCW:
  // radio.setCS(10);  //uncomment this if using Pro Micro
  radio.initialize(FREQUENCY, MYNODEID, NETWORKID);
  radio.setHighPower(); // Always use this for RFM69HCW
  // Turn on encryption if desired:
  if (ENCRYPT)
    radio.encrypt(ENCRYPTKEY);
  // Set up a "buffer" for characters that we'll send:
  static char sendbuffer[50];
  static int sendlength = 0;
  // SENDING
  // In this section, we'll gather serial characters and
  // send them to the other node if we (1) get a carriage return,
  // or (2) the buffer is full (61 characters).
  // If there is any serial input, add it to the buffer:
  if (Serial.available() > 0)
    char input = Serial.read();
    if (input != '\r') // not a carriage return
      sendbuffer[sendlength] = input;
      sendlength++;
    // If the input is a carriage return, or the buffer is full:
    if ((input == '\r') || (sendlength == 5)) // CR or buffer full
      // Send the packet!
      Serial.print("sending to node ");
      Serial.print(TONODEID, DEC);
      Serial.print(", message [");
      for (byte i = 0; i < sendlength; i++)
        Serial.print(sendbuffer[i]);
      Serial.println("]");
      Serial.flush();
      // There are two ways to send packets. If you want
      // acknowledgements, use sendWithRetry():
      if (USEACK)
        if (radio.sendWithRetry(TONODEID, sendbuffer, sendlength))
          Serial.println("ACK received!");
          Serial.println("no ACK received");
      // If you don't need acknowledgements, just use send():
      else // don't use ACK
        radio.send(TONODEID, sendbuffer, sendlength);
      sendlength = 0; // reset the packet
/*Gateway Side*/
#include <RFM69.h>
#include <SPI.h>
#define MYNODEID      2   // My node ID
#define TONODEID      1   // Destination node ID
RFM69 radio;
  if (ENCRYPT)
  // RECEIVING
  // In this section, we'll check with the RFM69HCW to see
  // if it has received any packets:
  if (radio.receiveDone()) // Got one!
    // Print out the information:
    Serial.print("received from node ");
    Serial.print(radio.SENDERID, DEC);
    // The actual message is contained in the DATA array,
    // and is DATALEN bytes in size:
    for (byte i = 0; i < radio.DATALEN; i++)
      Serial.print((char)radio.DATA[i]);
    // RSSI is the "Receive Signal Strength Indicator",
    // smaller numbers mean higher power.
    Serial.print("], RSSI ");
    Serial.println(radio.RSSI);
    // Send an ACK if requested.
    // (You don't need this code if you're not using ACKs.)
    if (radio.ACKRequested())
      radio.sendACK();
      Serial.println("ACK sent");
    Blink(LED,10);
void Blink(byte PIN, int DELAY_MS)
// Blink an LED for a given number of ms
  digitalWrite(PIN,HIGH);
  delay(DELAY_MS);
  digitalWrite(PIN,LOW);
I would really appreciate any suggestions on how this might not be working.
Thank you!
The RFM69HCW is not a LoRa device.
when you make a post about radios, start with "I live in and..."
so we know what laws apply
that's fine, if you live in asia, but not kosher in the USA. If you live in the USA, you are blessed with the biggest chunk of spectrum around, the 915 mHz ( 902 - 928 mHz ) Part 15 allocation, and the overcrowded 2.4 gHz allocation.
Hi Geek Emeritus,
Thanks for the reminder, I do live in asia. Therefore I chose the 433MHz :slight_smile:
srnet:
Hi srnet,
I understand it is a radio module therefore the communication can take place over a long distance where the node is somewhere remote. Still, I can not figure out why serial.print is not working in the void setup() code. Hope you could help thank you!
The title of you post does imply you want to connect a RFM69HCW to a LoRa device and the RFM69HCW is not a LoRa device.
If you are trying to use two RFM69HCWs to communicate then perhaps say how far this 'long distance' is and where it is, since the RFM69HCW may not be capable of what you want to do.
