Using rotary encoder with 2 Esp 32s' to control servo motor
Hello, a complete newbie here. So i was trying to send data using rotary encoder and esp 32 to control a servo motor. I want the sender to send 1 when the rotary encoder turns clockwise, -1 when it turns counter clock wise and 0 when the button the rotary encoder is pressed. Use code tags to format code for the forum.
THESE ARE MY CODES FOR THE SENDER.
#include <esp_now.h>
#include <WiFi.h>
#define outputA 32
#define outputB 34
#define outputSw 25
int counter = 0;
int aState;
int aLastState;
int nowState;
uint8_t macAll[] = { 0xC0, 0x49, 0xEF, 0x69, 0xB0, 0xA4 };  // Receiver MAC address
typedef struct struct_message {
  int angle;
} struct_message;
struct_message myData;
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
  Serial.print("\r\nLast Packet Send Status:\t");
  Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
  pinMode(outputA, INPUT_PULLUP);
  pinMode(outputB, INPUT_PULLUP);
  pinMode(outputSw, INPUT_PULLUP);
  aLastState = digitalRead(outputA);
  WiFi.mode(WIFI_STA);
  if (esp_now_init() != ESP_OK) {
    Serial.println("Error initializing ESP-NOW");
    return;
  esp_now_register_send_cb(OnDataSent);
  esp_now_peer_info_t peerInfo;
  peerInfo.channel = 0;
  peerInfo.encrypt = false;
  memcpy(peerInfo.peer_addr, macAll, 6);
  if (esp_now_add_peer(&peerInfo) != ESP_OK) {
    Serial.println("Failed to add peer");
    return;
  attachInterrupt(outputA, encoder, CHANGE);
  attachInterrupt(outputB, encoder, CHANGE);
  attachInterrupt(outputSw, encoderReset, FALLING);
void encoder() {
  aState = digitalRead(outputA);
  if (aState != aLastState) {
    if (digitalRead(outputB) != aState) {
      myData.angle = 1;
      nowState = 1;
      myData.angle = -1;
      nowState = -1;
    esp_err_t result = esp_now_send(macAll, (uint8_t *)&myData, sizeof(myData));
    //Serial.println(nowState);
  aLastState = aState;
void encoderReset() {
  myData.angle = 0;
  nowState = 0;
  // Nothing to do here since interrupts handle everything
THESE ARE MY CODES FOR THE RECEIVER.
#include <WiFi.h>
#include <ESP32Servo.h>  //motor
int mapAngle;
Servo myservo;  // servo motor name
/////////////////////////ESP-NOW//////////////////////////////
  int angle;
} struct_message;
int Counter = 0; // Moved declaration outside loop()
  //Serial.print("\r\nLast Packet Send Status:\t");
void OnDataRecv(const uint8_t *mac, const uint8_t *incomingData, int len) {
  //Serial.println("recv_something");
  memcpy(&myData, incomingData, sizeof(myData));
  int rawCounter = myData.angle;
  if (rawCounter == 1) {
    Counter++;
    if (Counter > 360) {
      Counter = 360; //LIMIT MAX COUNTER
  if (rawCounter == -1) {
    Counter--;
    if (Counter <= 0) {
      Counter = 0; //LIMIT MINIMUM COUNTER
  if (rawCounter == 0) {
    Counter = 0;
mapAngle = map(Counter, 0. 360, 0, 180);
  Serial.print("The New Motor angle is   ");
  Serial.println(mapAngle);
  myservo.write(mapAngle);
  //mapAngleValueP = mapAngleValueN;
  // myservo.attach(27);  // motor pinOut
  // while (! Serial) {
  //   delay(1);
  Serial.println(WiFi.macAddress());
    return;
  esp_now_register_recv_cb(OnDataRecv);
  // Nothing to do here since ESP-NOW callbacks handle everything
The sender keeps sending '0' repeatedly. NEED URGENT HELP! T_T. Thank you in Advance!!
Welcome to the forum
What should be sent when the rotary encode is stationary and the button is not pressed ?
nothing is supposed to be sent. I only want the esp 32 to send data for one time when it registers a change in the Rotary encoder. after which i will program the receiver address to add and subtract (++ && --) to keep track of a counter for 0 (minimum) - 360 (maximum clamp), which will be remapped to 0 -180 for the 180 degree Servo motor.
have a look at esp32encoder
