Using RTC DateTime outside of the if statement it was defined in
I am working on a project where when the device will record the time it is "turned on", via an on/off button, where there is a loopRunning variable that is toggled so that on the first press, the device turns off, and on the next press, it turns off and so on. Hence, there are two if statements: one of them gathers the time when the device first turns on, and the other is for all the things the Arduino will do after it is "turned on".
In the first if statement, I record startTime and the subsequent print statements show that this startTime is indeed the time when the device was first turned on. However, as soon as I step out of the if statement or into another if statement, I am getting completely incorrect values for startTime--no matter what startTime actually was, startTime.minutes(), DEC was always 28, and for day it was always 6.
So, is there a way I can get the correct values for startTime outside of the if statement? Below is the code I am using:
#include <RTClib.h>
#include <Wire.h>
#include <Adafruit_I2CDevice.h>
RTC_DS1307 rtc;
boolean loopRunning = false;
int onoffState = 0;
int prevOnoff = 0;
//pausing intervals - minutes
const int timeWater = 10;
//Define blank variables
DateTime startTime = (0,0,0,0,0,0);
  pinMode(onoff, INPUT);
  if(! rtc.begin()){
    Serial.println("Couldnt find RTC");
    while(1);
  if(! rtc.isrunning()){
    Serial.println("RTC is NOT running!");
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
  onoffState = digitalRead(onoff);
  //When device is turned on - gets correct startTime values
  if((onoffState==HIGH)&&(loopRunning==false)) {
    DateTime startTime = rtc.now();
    Serial.println(startTime.month(), DEC);
    Serial.print('/');
    Serial.print(startTime.day(), DEC);
    Serial.print('/');
    Serial.print(startTime.minute());
  //Everything below returns incorrect values for startTime
  Serial.println(startTime.day(), DEC);
  //Running everything else once device is on
  if (loopRunning) {
    Serial.println(startTime.minute(), DEC);
  Serial.println(onoffState);
  //Turning on and off
  if((onoffState==LOW)&&(prevOnoff==HIGH)) {
    loopRunning = !loopRunning;
    Serial.println(loopRunning);
  prevOnoff = onoffState;
Any help would be much appreciated, thanks!
You have more than one variable named startTime, each with their own scope
DateTime startTime = (0, 0, 0, 0, 0, 0);
Declare it once as a global then use it throughout the sketch
    DateTime startTime = rtc.now(); // LOCAL
  Serial.println(startTime.day(), DEC); // GLOBAL
I see, completely overlooked the fact that I was re-definining the variable.
Thanks for the help!
