Using RX and TX pins.
I have a mosaur transmitter reveiver pair and one arduino decillima for each.
I have been trying to get my transmitter-receiver pair working for a while and was having problems uploading sketches to my receiver board (some avrdude error). I then relaized that if I remove the pin going into RX the board starts working (though not receiving signals). So A little searching later and I found that adding a 10K resistor to the input into RX stops the board from stopping working.
Does this also stop the board from receiving signals? Should the sending board also have a resistor somewhere?
Heres the code on my receiving board:
  // for a motor
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  //I am running a motor though an H-bridge, this starts the motor turning
  digitalWrite(2,  LOW);
  digitalWrite(3,  HIGH);
  Serial.begin(2400);
  //if we receive any signal
  if(Serial.available() > 0)
    //consume the serial input so there is no more available
    Serial.read();
    //stop the motor for one second
    digitalWrite(2,  HIGH);
With the above code the motor will run IF the RX wire is not connected or there is a 10K resistor on it.
And the code on my transmitting board:
  Serial.begin(2400);
  Serial.print(3);
  delay(5000);
I'm not sure if the above transmitter code is working, I am not sure how to debug it and have made it as simple as possible.
Thanks,
Pooh
