Using SD card for persistent storage of a float array
I am trying to use an sd card as a way to keep values in a float array after turning off my arduino. I've been working on some code for it and I can save my array into the sd card without any issues. Where I am having trouble is when I go to save the data back into RAM. Any help would be appreciated. The code I have is below.
#include <SPI.h>
#include <SD.h>
 File numFile;
 while (!Serial) {
 if (!SD.begin(10)) {
   Serial.println("SD Error");
   while (1);
 SD.remove("nums.txt");
 //counter
 int i = 0;
 float nums[7] = {16.1, 16.2, 16.3, 16.4, 16.5, 16.6, 16.7};
 float numsFromSD[7];
 // Make File
 numFile = SD.open("nums.txt", FILE_WRITE);
 //Save array to SD
 for (i = 0; i <= 6; i++) {
   numFile.println(nums[i]);
 numFile.close();
 i=0;
//Where I am stumped
 numFile = SD.open("nums.txt");
 if (numFile) {
   // read file
   while (numFile.available()) {
     Serial.write(numFile.read());
   // close the file:
   numFile.close();
Written as text you can retrieve them with parseFloat(); written as raw binary (not the case but possible) will be by reading to a four-byte array, for example:
numFile.read((byte*)&numsFromSD[i], 4);
Thank you Lucario! It is working how I wanted it to now. Just to check though is this how you meant for me to do it?
#include <SPI.h>
#include <SD.h>
  File numFile;
  while (!Serial) {
    while (1);
  //counter
  int i = 0;
  // Make File
  //Save array to SD
    if (numFile) {
  numFile.close();
  i = 0;
  //What was added to read from file
    numsFromSD[i] = numFile.parseFloat();
  numFile.close();
  i = 0;
    Serial.println(numsFromSD[i]);
That should do the job just fine, at least when the element count is known...
