Using SdFat with String
Hello everybody,
Having problem with the SD library (see my post "Problem with SD library" in the section "TroubleShooting), I am going to use the SdFat library.
I would like to know how to use the "printName" method to get the result in a String object.
Thank you for your help.
Pierre
The following will get the file name for myFile and place it in an Arduino String.
  SdFile myFile;
  char tmp[13];
  // code to open mfFile goes here
  myFile.getFilename(tmp);
  String name = tmp;
  // verify that the file name is in the String.
  Serial.println(name);
The output for a test case is:
TEST.TXT
Thank you Fat16lib, I just have to use the alternate method getFileName(char*).
Pierre
